1850 box
Posted: Sun Apr 04, 2004 6:02 am
by Gibbonz
wont go into gear when changing 3rd to 2nd.<br>
Doesnt happen all the time but fails quite regularly.<br>
Is this caused by worn synchro's, which are on the way out as it wont go into 1st on the run, or is something else causing it.?<br>
Selector shaft bushings are all good.<br>
Cheers<br>
Rob Gibson<br>
NZ
gears
Posted: Sun Apr 04, 2004 9:29 am
by george
when you get downshift probs 3/2 its more likley to be syncros if its on the upshift 2/3 the there are other <br>
things to look for the main shaft circlip causes the 3/4 syncro to move and if you drive it in 3 or 4 and throttle on off the gear lever will move quite alot if you hold the lever the you can feel the movment in the box <br>
if you overhaul the box this circlip must always be replaced
oops
Posted: Sun Apr 04, 2004 9:35 am
by george
forgot to ask what box it is thinking off 3 rail and single<br>
rail g/boxes in info in first esay not quite awake yet!!
Oops
Posted: Mon Apr 05, 2004 8:40 am
by Gibbonz
thanks for the reply.<br>
It is a 3rail box.<br>
It will be taken out and overhauled later this year. I can live with it for a few more months.<br>
Poor ole Dolly boxes.<br>
Have had bad luck with them once the miles get up.<br>
Same old story eh!<br>
' Bearings and Synchros'.<br>
Where is the best place to get a O/H kit with everything I need?
