Page 1 of 2
1300 FWD Clutching at straws......?
Posted: Fri Sep 01, 2006 2:44 pm
by algtj
Play on words.<br>
Ok, lost the clutch totally on the FWD today, most entertaining driving six miles home!<br>
Pulls the car to pieces to replace the slave cylinder (Done) however the thrust release bearing is flapping in the wind around the input shaft.<br>
I suspect I will need to remove the gearbox input shaft to deal with this?<br>
Any ideas anyone?<br>
To remove said shaft the manual states I need a special tool, anyone have one?<br>
Scott, be wary about using the same garage again I suspect the spotty youff that works there has no mechanical sympathy or apptitude with old cars. Please don't read this as me having a go about the car, it's fantasic! <!--EZCODE EMOTICON START :D --><img src=
http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
special
Posted: Fri Sep 01, 2006 3:50 pm
by george
no you can do it whithout the tools (all it is anyway is a bolt and slidink hammer )<br>
just put a bolt into the internal thread (you'll see a thrust one in the shaft remove it )mole grips and tap the grips if its that tight otherwise it'll pull out with ease
Re: 1300 FWD Clutching at straws......?
Posted: Fri Sep 01, 2006 3:54 pm
by dollysteve
I got mine out by welding a washer on the end of bolt, wound it in to the back of the input shaft, a few quick tugs with the slide hammer and it was out.
Posted: Fri Sep 01, 2006 5:39 pm
by algtj
Sorted! Took the opportunity to lubricate the rear input shaft bearing whilst at it.<br>
So we now have a nice quiet gearbox, clutch that works and the speedo working too. <!--EZCODE EMOTICON START :D --><img src=
http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Should have been in bed...... Nights!
Posted: Sat Sep 02, 2006 2:50 am
by Carsreunited
Just read this Al. I know you aren't having a go as you are too polite for that! I'm glad you have got it sorted and I am annoyed that the guy I paid to repair it obviously didn't!<br>
In all honesty, I would have liked to drive it around for a few weeks so that any niggles could have been sorted out by him one way or the other. At least you have it sorted now and I hope the whole experience will be bit more enjoyable!<br>
(Sorry Sophie!!, its a good car honest!)<br>
Posted: Sat Sep 02, 2006 9:47 am
by slant04
I've got some of the input shaft grease if you need some. Oil seal ok now?
Posted: Sat Sep 02, 2006 2:01 pm
by algtj
Problem is Scott, I'm just too impatient! <!--EZCODE EMOTICON START :D --><img src=
I used some aeroshell hi temp aircraft grease for the input shaft and bearing. All seams quieter and if it's good enough for historic aircraft.....!<br>
The car was working fine last night however I have done around 30 miles today and it's playing up again!<br>
Difficult to select gears, clutch judder and moving whilst clutch peddle depressed.<br>
I checked the reservoir and there was no loss of fluid this time, so the new slave cylinder works. Should I try bleeding the slave again?<br>
POL
Posted: Sat Sep 02, 2006 8:11 pm
by redrichie
So it's not just my Dolly that gets treated to Aircraft grade greases, adhesives and lubricants then.....<!--EZCODE EMOTICON START :eek --><img src=
http://www.ezboard.com/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br>
I'd be shocked at you using anything else Al. <!--EZCODE EMOTICON START :b --><img src=
http://www.ezboard.com/images/emoticons/tongue.gif ALT=":b"><!--EZCODE EMOTICON END-->
Re: POL
Posted: Sun Sep 03, 2006 12:03 am
by Carsreunited
All I can say Al is that before the box change the clutch operation was faultless. I'm no expert on anything least of all clutches. Hope somebody else can offer advice on why its creeping.<br>
re
Posted: Sun Sep 03, 2006 12:36 am
by george
try bleeding it again if it doesnt work then take a look at the master cyl assuming you replaced the slave seals<br>
if it's creeping it's a loss of pressure could be air or bad seals
Re: re
Posted: Sun Sep 03, 2006 9:08 am
by algtj
Will take a poke at the master cylinder next. Common sense told me to replace the whole lot...... But you know the story! <!--EZCODE EMOTICON START :D --><img src=
OM15 for the brake system?! If only the seals would take it! <!--EZCODE EMOTICON START :D --><img src=
Re: re
Posted: Tue Sep 05, 2006 12:24 pm
by slant04
had a thought. Its not the clutch pivot bolts come loose?
Re: Creep
Posted: Tue Sep 05, 2006 12:49 pm
by mbellinger
If she is creeping with the clutch fuuly depressed you are not disengaging the clutch fully - no two ways about it.<br>
Thus the problem must be:<br>
1. Pedal mount and pivot arm or<br>
2. Slave cyl or<br>
3. Master cyl or<br>
4. Release bearing<br>
Since 1 is easy to check, and you have attended to 2 and 4, that only leaves 3 to investigate. Did you replace the release bearing or merely re-seat it? Was it knackered?<br>
I find it best to start the pedal end of things and work towards the engine. A methodical approach will find the culprit in the end. Good luck!
<p>Martin<br>
1968 Triumph 1300FWD<br>
1975 Triumph 1500TC Auto<br>
1989 Honda Civic 1300 Auto<br>
2006 Mondeo 2.0 Ghia X Auto<br>
2002 Renault Scenic<br>
</p><i></i>
Re: Creep
Posted: Tue Sep 05, 2006 4:33 pm
by algtj
I reseated the bearing.... I'll recheck the pivot arm bolts.<br>
As the clutch was working fine until the slave cylinder let go, I didn't bother with the master cylinder..... <!--EZCODE EMOTICON START :o --><img src=
http://www.ezboard.com/images/emoticons/embarassed.gif ALT=":o"><!--EZCODE EMOTICON END--> <br>
Still haven't got around to re-bleading the system. probably at the weekend, if not in Scotland with work......<br>
Once the clutch is sorted it will be for sale (Sorry for advertising!)<br>
As the wife prefer's the Manta...... No accounting for taste!!!<br>
If anyone is interested PM me.
Re: Sale?
Posted: Tue Sep 05, 2006 5:01 pm
by mbellinger
Are you at TDCIR?<br>
If so lets talk then.<br>
I am interested BTW.....<!--EZCODE EMOTICON START ;) --><img src=
http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
<p>Martin<br>
</p><i></i>
