mis reading speedo
mis reading speedo
The speedo on my fwd misreads, at 22mph it reads 30. at 29 mph it reads 35/36 mph. at stand still it reads about 5 mph but blipping the throttle sometimes makes it drop!!. at faster speeds (approx 70/75) it waves between 85 and 100.<br>
could this be a stretched cable? <br>
apart from that its running great (carbs need adjusting slighty) and maybe a service as i havn't done anything to the engine yet.<br>
all help and advice gratfully received
Re: .
Justyn..Do you have the right final drive. Not sure this is a triumph problem but in the olden days (ahhh) it used to make a difference on minis. Also, dumb as it seems, do you have the right size wheels?<br>
I guess I'd change the speedo as well, just run one inside the car (ie out of the dash) and see what readings you get ..<br>
<p>1981 1500 HL -daily driver<br>
1980 Inca Sprint - high days and holidays (and any other excuse) <br>
1978 Inca Sprint Engine back in - timing perfect (had to phone a friend !) exhaust next then wire up the overdrive and its on the bay<br>
1978 Yellow 1850 auto sprint-notvery-alike - nasty shunt - undecided<br>
1973 Mimosa Sprint - sold, awaiting collection end of september </p><i></i>
Triumph1300
HHHHmmmmmm
Probably the speedo head, if it's a 1300 FWD I've a couple of spare speedo's knocking about, usual question, where are you in the country, or are you going to TDCIR??<br>
My phone number is in DM under Advertising Officer<br>
BWJ - Annoyed with the DVLA!!!<!--EZCODE EMOTICON START >: --><img src=http://www.ezboard.com/images/emoticons/mad.gif ALT=">:"><!--EZCODE EMOTICON END--> <br>
at least...
.. you have something from your speedo! Mine isn't reading anything at all as the gearbox end seems chewed. New cable and still nothing!<br>
Must sort that out as I'm sick of working off the revs only!<br>
Tim
Tim
Re: at least...
David ,wheels are right size but i necer thought to check the tyre size.... duh!! i think that will be my problem, i took the tyres of my dolly and put on the 1300 wheels.<br>
Brian, yes please. i will be at hatton.
Carsreunited
Re: at least...
If the needle is fluctuating between 85 and 100mph, the head of the cable is knackered. Shouldn't dance around like that.<br>
Re: at least...
could be my driving<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <br>
do you mean the end of the cable where it sits in the speedo?<br>
J.
J.
Carsreunited
Re: at least...
More likely gearbox end. New cable either way I think.<br>
Re: at least...
thanks scott i will look into that.<br>
J.
J.
Triumph1300
and next
Does that mean you want me to see if I've got a spare speedo cable I can bring on Sunday, as well as a speedo head???<br>
Bruce WJ( Still happy)
Re: and next
thanks for the offer bruce, i have a cable and at the moment im working on getting the car running. new thread time.<br>
J.
J.
triumphsonthebrain
Re: mis reading speedo
Hi there,<br>
I had the same problem when I fitted a Dolly 1300 gearbox in my Toledo. Remedy, fitted a Dolly 1300 speedo!, hey presto, 30 mph on the clock at 30 mph.<br>
Sorted!.<br>
Sorted!.<br>
