Cross-threaded Spark Plug Hole
Posted: Mon Jul 10, 2006 2:19 am
by USASPRINTMAN
How do you fix a spark plug hole that has the threads cross-threaded?<br>
Let's just say this head is on a Dolomite 1850 and not the Stag I just bought (since this is the Dolly board)...<br>
The new plug is in and it's tight. But I should not have forced it in, and now I regret my mistake. Probably it will be OK if I never take out the plug, but I do need to fix it. <br>
Cheers,<br>
Richard Truett<br>
How do you know...
Posted: Mon Jul 10, 2006 9:32 am
by Jon Tilson
its cross threaded? If its gone in okay and the sealing washer is nipped it will be okay. Next time you take it out you can make a thread cleaner with an old plug...just file a slot in the threads for the crud to go in like a thread tap has. Some copper grease and you may well be lucky.<br>
Failing that its helicoil time.<br>
Re: How do you know...
Posted: Mon Jul 10, 2006 2:21 pm
by 2F45T4U
Just leave it in there! I'm sure mine would of lasted the life of the rest of the engine if I hadnt touched it!
leave it in...
Posted: Mon Jul 10, 2006 5:20 pm
by george
just done a 1.0 corsa thats decided to let the centre electrode go (gm plugs with no milage on them ) nothing to stop it going in the cyl <br>
stuffed piston etc..etc... dont leave them till it missfires !!
cross thread
Posted: Mon Jul 10, 2006 5:28 pm
by george
snap-on do some nice plug re-threaders (loads of grease on it so it catches any metal) if that doesn't work then it's head/s off and to your local eng shop<br>
over here most will not do it in situ <br>
Centre electrode let go
Posted: Mon Jul 10, 2006 5:42 pm
by samgamgee911
Hey George, I have heard of this happening to Sprint's in the past. How would you check if it caused damage - would a compression test be of any use?<br>
Of couse if it bent a valve then you would know right away but what if it put the debris out the exhaust valve - would you be very lucky and need no further action?<br>
Cheers, just wondering
noise
Posted: Mon Jul 10, 2006 6:38 pm
by george
on this corsa i could see down the plug hole and the piston was quite shiny so a lot of contact had been made by the plug bits <br>
(when i removed the head no bits of the plug were present so it gone the way of the exhaust valve) <br>
prior to that after the coil pack was removed no2 was realy oily so the pressure was coming out the plug<br>
i put a new set of plugs in but when i did it was smoking like a good un the bad news was the piston was really stuffed buy the centre electrode dancing around
Re: noise
Posted: Mon Jul 10, 2006 7:56 pm
by Carsreunited
When I had one of mine helicoiled on the stag. The guy did it in-situ and started the car without the plug in the new heli-coiled hole. The theory being that any debris would be blown out the hole on start up. Didn't have any problems with it.<br>
