spark plugs
spark plugs
Me again, got the club plug tubes in, new plugs and cam cover gasket, sodding thing wont start! Thought i'd check the plug gaps, cant get the things out now, any tips on this?
Re: spark plugs
Normally heat would help but not much help when you can't start it. What are you using ? If it is a T bar type with universal joint these are not much cop. Use a deep socket with an extension and a ratchet and they should release. Did you do them up too tight last time?<br>
Mike<br>
80 Sprint
Mike<br>
80 Sprint
Re: spark plugs
If its because they have undone and you just can't reach them an upturned HT lead boot is a perfect tool for extracting them, or a bit of rubber tube half pushed over a screwdriver of appropriate shank size.<br>
Plugs are taper seated and should only be done up to 8lbft...ie bugger all!
Re: spark plugs
Cheers men, i can undo them but cant seem to take em out. Like the rubber tube idea, will try that. Must say the standard plug spanner for the sprint is quite crap <!--EZCODE EMOTICON START :smokin --><img src=http://www.ezboard.com/images/emoticons/smokin.gif ALT=":smokin"><!--EZCODE EMOTICON END-->
I use...
one of them spring loaded pick up tool things that are a couple of quid at any market...<br>
But a length of stiff rubber or some long needle nose pliers also do the job.<br>
The decent plug spanners have a rubber inset to grip the plug for you but mine has long since succombed to the ravages of time..<br>
dollysteve
Re: I use...
Most plug sockets have a rubber insert for exaclty this reason.
Re: I use...
Turn the car upside down and shake it <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Re: adam...
I go on Saturday morning to begin drinking and enrol on Monday. Wooo hoooo <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Re: adam...
Not drinking 'till Monday? Bizarre behavior for a student <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <br>
Tinweevil
Tinweevil
