Page 1 of 2
Uprated Spring (oil pump)
Posted: Wed Jul 05, 2006 9:32 am
by MaddMart
Does any one know where to get an uprated oil pump spring from? I've tried Moss but they say they are discontinued (Moss part no. STR560). Also tried Fitchetts.
<p></p><i>Edited by: <A HREF=
http://p206.ezboard.com/bthetriumphdolo ... omiteuk</A> at: 5/10/06 2:03 pm<br></i>
Re: Uprated Spring
Posted: Wed Jul 05, 2006 11:08 am
by davepoth
tried S&S Preparations? They're mainly TR7, but I guess the part is the same.<br>
http://www.ss-preparations.co.uk
Re: Uprated Spring
Posted: Wed Jul 05, 2006 12:54 pm
by Carsreunited
Hart Racing (Stags). I believe they use a stronger spring.<br>
Re: Uprated Spring
Posted: Wed Jul 05, 2006 1:50 pm
by MaddMart
Thanks guys, I phoned S&S but they didn't have one so rang Tony Hart. I'm glad I did now, as he advised not to do it (well maybe on a worn engine). He says they only run their racing Stags up to around 50psi.
<p>Martin<br>
<!--EZCODE LINK START--><a href="
http://www.dolomitesprint.com/" target="top">www.dolomitesprint.com</a><!--EZCODE LINK END--></p><i></i>
Re: Uprated Spring
Posted: Wed Jul 05, 2006 4:58 pm
by Carsreunited
That seems remarkeably low for an under load figure. Mines anywhere between 35 and 70.<br>
Re: Uprated Spring
Posted: Wed Jul 05, 2006 5:43 pm
by MaddMart
I thought that was a bit low too, as I mentioned mine was 70 to 75 psi. Mine had recently dropped to around 60 though but still not bad.
<p>Martin<br>
Oil pressures
Posted: Wed Jul 05, 2006 7:54 pm
by johnorr
My 1850 never reads above 50 or below 35. Within tollerance?<br>
John, YDP300T (no mot!)
Re: Oil pressures
Posted: Wed Jul 05, 2006 9:47 pm
by MaddMart
If my Sprint never read above 50 I would be thinking maybe big ends and/or mains or deffo something worn, maybe pump. I would assume similar for an 1850.
<p>Martin<br>
Re: Oil pressures
Posted: Wed Jul 05, 2006 10:29 pm
by 2F45T4U
the oil pressure stated in the haynes is 40-60psi at 2000 rpm for both 1850 and Sprint engines.
Well...
Posted: Wed Jul 05, 2006 10:42 pm
by Jon Tilson
John I've seen yours hitting the relief valve nice and early. That's all you want to see.<br>
You dont want it too high or it will blow the oil pump seals.<br>
60 is quite enough....<br>
I'd be happy with 50 on a stag V8 as its got more bearings to blow it out.<br>
My p6 V8 is 25 at cruise and no knocks...<br>
Re: Well...
Posted: Wed Jul 05, 2006 10:45 pm
by 2F45T4U
Mine is 60 at idle <!--EZCODE EMOTICON START :eek --><img src=
http://www.ezboard.com/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br>
Well so says the gauge!
Re: Well...
Posted: Wed Jul 05, 2006 11:47 pm
by MaddMart
When it's cold, maybe!
<p>Martin<br>
Posted: Thu Jul 06, 2006 10:58 pm
by SprintV8
On the Stag engine because of the single timing chain a uprated pump/spring will put extra strain on the tensonier and chain causing premature chain failure if not checked regularly.<br>
From the Stag man himself (Not me).
<p>1980 Dolomite SprintV8 (360bhp of TVR AJP V8 Pumping Alloy Coming soon !)<br>
</p><i></i>
Err how exactly?
Posted: Fri Jul 07, 2006 12:06 am
by Jon Tilson
The timing chain tensioners dont have an oil feed nowadays....welll the last few I have done dont and with no ill effects. Even if they did i dont see how some oil squirting through a hole is going to force the tensioner out....it surely only ratchets out when the chain is slack.<br>
He's on drugs....<!--EZCODE EMOTICON START :hat --><img src=
http://www.ezboard.com/images/emoticons/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END--> <br>
Posted: Fri Jul 07, 2006 8:15 pm
by SprintV8
That's because they all steered toward's timing belt's.<br>
Having served my apprenticeship with Mazda Car's I'm totally disagree with you.<br>
323 626 929 B/E 1800 2000<br>
All use a tensoiner with a click type adjuster that is pushed out by a small oil hole drilled into the block that feed's the tensioner.<br>
Sure the Stag use's the same set up.<br>
It just isn't going to adjust itself when the chain goe's slack.<br>
On Drug's I very much doubt it<br>
</p><i></i>
