It is currently Wed Oct 21, 2020 9:47 am
PostPosted: Sun Oct 18, 2020 1:14 pm
Would anyone have spare dolly aerials knocking about or know of a supplier of them please?
Will
PostPosted: Sun Oct 18, 2020 9:30 pm
Hi Will
I bought mine for the rear wing on my car from Machine 7. it’s an aircooled VW aerial. It has the correct steep angle needed for the rear wing. Not sure if yours is front or rear wing fitment but if it’s a steep angle you need, then I’m pretty sure it will do the job. It’s decent quality and stainless steel.
https://www.machine7.com/product.php?xP ... &xSec=1186
PostPosted: Tue Oct 20, 2020 5:58 pm
Cheers Bish
It’s for the front wing unfortunately, I bought a similar aerial without checking the diameter which on the dolly front wing is rather large 🙄
PostPosted: Tue Oct 20, 2020 9:02 pm
Yeah, that does look to be a bit of a blighter of a hole!
The angle doesn’t look to be too different to the rear wing where my aerial is fitted though? If the base spans the hole you have it could work?
Here’s a pic - sorry the lighting in my garage isn’t the greatest, but you get the idea. The black base of the aerial is ovaled - smallest diameter is the width at 22 mm, largest is the height at 40mm.
