It is currently Tue Apr 23, 2019 4:50 pm
PostPosted: Mon Jan 07, 2019 8:03 pm
I'm looking for a repair panel for the front top of the front wing : the outer panel above the headlights
Is this the panel mentioned in the club spares " front wing repair" or am I wrong ?
Regards,
Jan Crauwels
Belgium
PostPosted: Mon Jan 07, 2019 8:07 pm
Unfortunately the 'front wing repair' panel is the bottom bit between the wheel arch and the front door.
Your best bet currently is sourcing a used wing that is good in that area that would render a repair for you...or fit a full GRP wing...
Which side?
PostPosted: Tue Jan 08, 2019 6:03 pm
I might have some available, working away so it will be 2 weeks before I can check. As Alun asked - which side?
PostPosted: Fri Jan 11, 2019 7:29 am
HI,
Thank you for the reply.
The LH front wing is to good to replace with a GRP-one
So, we'll repair it with some home made sheet metal. You don't need to look for any old wings to cut.
Thank you and beste regards,
Jan
