It is currently Fri Mar 05, 2021 3:49 am
 Post subject: 1500 parts.
PostPosted: Tue Nov 17, 2020 10:38 pm
I will be stripping the mechanical parts from this low mileage 1500HL in a few weeks time to do an engine swap, so everything is up for sale.
The engine has only done forty-odd thousand miles but it did get hot when I last ran it during the Summer, so it will need inspecting but I am happy to give it to someone FOC for a re-build.
The gearbox is good.
The rear axle is good, it has a slight pinion seal oil leak but has manually adjusting brakes and has just been fitted with new wheel cylinders and shoes.
Other parts available from the car include the subframe, prop-shaft, radiator, carbs and inlet manifold, exhaust manifold and downpipe, distributor, starter motor, alternator, brake master cylinder, some front suspension components and a good set of rear springs and shock-absorbers.
I also have a pair of new self adjusting rear wheel cylinders, 2 x new sets of self adjusting rear shoes, a pair of reproduction HS4 carbs from the 1990s with the black plain type jets, some new aerosol cans of Sandglow and a pair of 7" halogen headlamps with H4 bulbs (bought for a Midget but I notice that a few people have fitted these to the square headlight models).
If there is anything else that I haven't listed, just ask.
All parts will be going cheap to fellow enthusiasts and I am happy to post the smaller items at cost.
 Post subject: Re: 1500 parts.
PostPosted: Wed Nov 18, 2020 12:20 am
Hey Glen, where are you located?
PostPosted: Wed Nov 18, 2020 5:56 pm
Sorry, thought it was on my profile. Midhurst, West Sussex.
PostPosted: Wed Nov 18, 2020 5:57 pm
Axle, carbs and manifold, exhaust manifold and down-pipe, and spare set of HS4s all provisionally sold.
PostPosted: Wed Nov 18, 2020 5:58 pm
There is a fairly new clutch slave cylinder on the car too.
PostPosted: Fri Nov 27, 2020 12:20 am
I could be interested in the engine but wouldn't be able to collect ill the new year due to my shifts at work
PostPosted: Fri Nov 27, 2020 7:27 pm
Ok. If it's still here after Christmas I will let you know.
PostPosted: Sat Nov 28, 2020 12:53 pm
alternator?
how good is it? what output is it? and could you deliver ng21 area
mine is just coping but not good,,,did buy new alternator but that burnt out just after guarantee ran out,i did have a look inside and it looks so much like chineses
thanks nic
PostPosted: Sun Nov 29, 2020 8:57 am
alternator?
thanks nic
Nic,
Yes, still have the alternator, I guess it is just the normal 1500 one, as the car is completely standard. It seems to work fine. I could post it at cost.
Glen.
PostPosted: Sun Nov 29, 2020 11:55 am
you av pm :D
PostPosted: Mon Nov 30, 2020 8:13 pm
cheers, much appreciated.
PostPosted: Sat Jan 09, 2021 11:08 pm
The gearbox is now available again. Only 42,000 miles and works perfectly.
PostPosted: Tue Jan 19, 2021 9:48 pm
Gearbox now sold and has actually, physically gone this time.
PostPosted: Sat Jan 30, 2021 10:58 pm
I still have for sale a pair of new self adjusting rear wheel cylinders, 2 x new sets of self adjusting 1500 rear shoes, some new aerosol cans of Sandglow paint, a new 1500 fuel pump and a pair of 7" halogen headlamps with H4 bulbs (bought for a Midget but I notice that a few people have fitted these to the square headlight models).
