Right some more pics....
Here is a few odds and ends that needed doing;
It was noted that the vinyl covering on the C Post was starting to lift, so investigation revealed that there was the start of corrosion under there, the vinyl was carefully lifted off (it was extremely brittle and the use of warm air helped it's removal).
The other side was also removed but it was found to be in excellent order and didn't need any remedial work doing to it.
You may recall that the rear quarter bumper mounts had been badly damaged (on both sides), this was probably due to impact damage and then rust setting in.
The rusted area was cut out and a new piece formed from sheet steel.
Again (rather like the roof repair) this was then welded into place then the welds ground down to produce a nice even surface.
It was also time to tackle that large dent on the underside (above the tail-pipe). this was pulled out using one of those slide hammer things that welds itself to the dent (sorry don't remember what it is called
It was also found that the back panel itself was bent slightly and again this was pulled and dressed out to it's original profile.
More to follow
