David
I picked up from somewhere that you have the Haynes manual – in your comments relating to the gearlever connection on the gearbox you have very kindly purchased and are transporting on my behalf.
This website, also mentioned elsewhere on the Forum,
http://www.vitessesteve.co.uk/, has copies of the factory workshop manuals. If you feel that you need access to them. The Haynes manual has had a lot of the information from the workshop manuals copied straight across, with some additional information and of course the photos that are often more useful.
I have had a quick look through my copy of the factory workshop manual here this morning in the hope that I might find some technical information relating to setting up the front of the car. In the body area of the manual is comment on using a Churchill jig for setting up all the datum points. There is nothing there though forward of the subframe mounting points. And since you are putting everything back together with the subframe in (the assumption being that it is not distorted in any way) then I think you should, or I would hope, that you do not have too many problems.
I have also checked the General Specification Data sheet at the front of the manual 04-4 and 04-5 and there is nothing there which I think would be of any great help.
However I am attaching a page out of the manual which describes the setting up of the front suspension camber and the adding and or removing of the shims which we have covered before.
Hope that is of some help.
Robert
