More work done this weekend and last, self isolation is working for me!
The underbonnet area has been painted with my own mix of Vermillion Smoothrite, it doesn't look it in the pix, but the colour is a near pefect match to the untouched original colour on the body plate now affixed to the shell
I've refitted all the underbonnet parts as well as all the metal brake pipes and the servo and master cylinder assembly.
Antiroll bar and new poly tie bar bushes fitted.
N/S eyebrow try fitted.
Last job today was to fit the new rear wheel cylinders and shoes and set up the rear brakes, finally adjusting the handbrake cables to fit. I've also done a preliminary bleed of the system and i'm getting fluid from all 4 bleed screws but no pedal just yet. I haven't given up, BUT I do suspect the master cylinder as it's the only "not new" part of the brake hydraulics. If' it's duff it's no biggie these days, Alun is only a few miles away!
Next weekend's task, bleed the brakes thoroughly, then, if successful, I can move onto finishing off the downpipe fabrication Including installing the secondary oxygen sensor and it's "cheater" and fitting the rest of my semi Sports exhaust, a Rimmers type centre box and cross axle pipe, but with a twin pipe stainless rear box of unknown ancestry I got from Tony (migwelder) at the Oxford show a couple of years ago.
I'm just hoping all this Covid 19 business is sorted by October and they'll let us into Scotland on the RBRR!
