It is currently Fri Apr 19, 2024 11:24 am
Post new topic  Reply to topic  [ 54 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: gear box pics
PostPosted: Wed Nov 07, 2012 6:14 pm
 Post subject: Re: triumph rs2000
PostPosted: Wed Nov 07, 2012 6:41 pm
Strewth! If thats how a Type 9 fits, I'm very glad I stuck to Vauxhall Powertrain!
Whilst it is obvious that you had very little choice, I am seriously concerned about chopping out the tunnel stiffener rib, this is quite an important structural member, being part of a box section that connects the 2 sill boxes, hacking it out is bound to compromise the shells rigidity.
I don't want to come over all heavy, but I earnestly suggest you find some way of replacing this lost section, perhaps across below the tailshaft housing would be possible?
PostPosted: Wed Nov 07, 2012 7:05 pm
ah yeah thats gunna have a brace made up to put the strength back into it, gunna brace it underneath the box so i can retain the bolt in tunnel and it will also be the gear box mount, the bottom end of that rib is badly rotten so its gotta come of all the way round as yet, but thanks for pointing that out
PostPosted: Wed Nov 07, 2012 7:48 pm
:thumbsup:
Keep up the good work, I love seeing something different! It makes me a little less lonely to know there are other nutters like me out there!
 Post subject: Aye............
PostPosted: Wed Nov 07, 2012 10:55 pm
Strewth! If thats how a Type 9 fits,.....
Onto a slant four you fit a T9 using the somewhat shallower Triumph bell housing and a shortened gear lever remote
(as in Vitesse/GT6 conversions). The gear lever then is located in the normal location.
A Sierra gearbox mount can be easily mounted into a 1500/1850 o/d cross member.
I have not looked at this myself, but I do know that Transit vans using a T9 had the gear lever much further forward (on top of the 'box?)......
PostPosted: Sat Dec 29, 2012 9:47 pm
well chaps and chapettes dosent look like this is gunna see the road, reasons outta my hands shes going on an oval, i thought about selling, but who wants a mad half built project so shes guna be a classic(style)hotrod i cant part with her now im this far into it, she aint gunna have no far out mods than whats done allready, ill be keeping the engine and box arrangements just ad a cage and proper race seats and she'll be on track,
PostPosted: Fri Feb 08, 2013 5:58 pm
ignore all that,,, on wards and upwards :mrgreen: :mrgreen: :mrgreen:
work is going on but not really much to update, just get all bracketry and bits fabbed up, work shall be progressing soon as iv bin building a euro rod 4 stansted raceway 4 a play toy
PostPosted: Sun Mar 17, 2013 3:12 pm
updates....
engine mounts fabbed up (tackd 4 now)
and g/b tunnel / bulkhead, so far only tacked together
then made a box up 2 hide the coil pack and rear thermostate
Image,
i then dicided after tacking it together to do away with the coil pack and use the original coil on plug set up, just got to now figure out how to connect these up 2 the esc unit
still got to finish the other side but still debating weather 2 have a hydro clutch or use the cable ?????????????
but thanks 4 looking
PostPosted: Sun Mar 17, 2013 3:35 pm
Ay up Gav, good to see you over here. Have you seen my project thread?..........................
Mine is suprisingly staying Boggo standard, which is probably a first for me, but I am hoping to make her a nice, usable classic ready for the show season.
On a different note, I had a couple of those RS engines many moons ago, one std, one an all steel HT racing lump that was "supposed" to have been originally built for one of the F2 works rally cars. Wish I still had that one cos it was a nice engine.
PostPosted: Sun Mar 17, 2013 5:38 pm
hello mate, yea i c a thread on ts about it.
surly after seeing some of your work it wont stay boggo for long :mrgreen:
PostPosted: Fri Apr 19, 2013 10:18 pm
more pics which bring me more or less up to date :) :evil:
Image :mrgreen:
bulkhead all welded, just smoothen em better Image
and the subframe mid work
just 2 blank of were its bin chopped and delete the front block mounts :twisted:
PostPosted: Mon May 06, 2013 9:50 pm
more up 2 date pixs
PostPosted: Fri May 17, 2013 11:12 pm
:eyes4u: :mrgreen: :suntan: :twisted: :evil:
pictures sayit all much easier
 Post subject: Re: triumph rs2300
PostPosted: Fri Jul 19, 2013 8:53 pm
updates
bin a busy bugga on me beloved toledo,
1stly ive more or less finished the wiring bar a switch or 2, so we manged to get power to the engine and went for a start up with sad results as the engine had no compression in the 1st 2 cylinders so instead of a pricey rebuild i was gunna replace but couuldnt find a rs engine in my price range so then i stumbled on an ad for a 2.3 galaxy engine(exactly the same block) 200 pound 2 my workshop door result, its far from a straight foward bolt in job, but more on that another time,
all doors bin stripped down for prepareing and 1 caused me a rite head ache but after watching a panel beater replace a door skin i was confident 2 chop the bottom rear door skin of and make a panel up stich welded and folded and impressd me self.
front suspension and wish bone fitted and sprayed even reused the polybushes as they were still in great condition, front shocks that came with her a fubar so for now i chopped 3 inches of the springs so shes rolling but im now after new ball joint covers each side ??? any ideas? and saveing for gaz coileys and green pads
made a battry box in the boot and a fuel tank in place, ive gone for an ax tank a, because i had it b it fitted str8 in cits not lgunna rot, :), also flushed the tailgate and fitted a popper to open the boot .
made me own sill covers after heating and folding metal over the good sill, had to do it in 2 pieces but its not turned out to bad, prepare the arches to be rolled as im having the wheels banded to 7 inch on the backs
propshaft im having made so waiting on funds for that, hand brake fitted and remote gearlinkage finished , now the cars being teared apart again for the wonders of body work and final welding,
still im always a believer in pixs Image
thanks for looking
PostPosted: Fri Jul 19, 2013 10:09 pm
Great progress here! What colour or final 'look' are you aiming for?
Users browsing this forum: No registered users and 58 guests
