Cracking job has gone on here....
Well impressed.
You're very kind!. First proper restoration this one, too.
I also thank you for your previous information on the early rev counter. Ive actually just purchased the proper type, could you put it into laymans terms exactly what i'd need to do to fit it into mine?
I.e. what i need to swap about, add, remove etc. Im a bit dim with technical terms until ive actually done a job.
In other news, stripped a brand new rear cylinder, bought a new one in error that was wrong, bought another one, fitted it today, bled the system and at last, for the first time since i bought it, it has brakes.
Sheared both downpipe bolts so i bought a new manifold, then sheared a bolt getting the manifold off. So ive got to wind that out somehow. For the MOT, which i theoretically have to have within 7 days, i need to finish the welding, fit the fuel tank and fuel lines, fit the exhaust manifold and exhaust system, fit an accelerator cable, repair one tyre and fit another, fit the front and rear lights and do a full fluid change.
I can probably do it, but i cant afford to insure it because ive been faffed about with jobs i was supposed to have but now dont for some reason - so its academic.
