It is currently Wed Jan 23, 2019 1:14 pm
Post new topic  Reply to topic  [ 957 posts ]  Go to page Previous 150 51 52 53 5464 Next
PostPosted: Tue Jun 20, 2017 7:37 pm
Thanks guys, but only a simple paint over for now.
But while the servo is out, I might as well put in the throttle
pedal strenghtener from Alun.
Luckily for me, my bulkhead has a grommet in the third hole,
so no need to drill :)
I haven't put the pedal on the other side yet, the bolts are merely for
the picture.
have you got that plate on upside down ?
P.s not taken my servo out yet,do i have to remove the parcel tray to gain access to the servo
PostPosted: Tue Jun 20, 2017 7:50 pm
TDC Spares Officer
Na he's cool.... and the plate's on the right way up. You can see it on RUK being an auto which is what the plate is based on I believe.
You can get the servo off without taking out the parcel shelf. However, if you have strong manly hands like me access is rather tight! :wink:
PostPosted: Tue Jun 20, 2017 7:51 pm
TDC Spares Officer
More to the point, Mahesh, get on with the car. You've been slacking recently. :lol:
PostPosted: Tue Jun 20, 2017 7:52 pm
TDC Sprint Registrar
I only pulled down the carpet to remove the clevis pin and undo the two internal nuts. Did not fancy taking out the parcel tray again.
Don't forget the two nuts on engine side of the bulkhead.
PostPosted: Tue Jun 20, 2017 7:57 pm
Slacking :lol: :lol: :lol:
I've been out driving the car, hence the
pedal strenghtener.
James, let me know when you release a
pedal rubber from the vault :wink:
PostPosted: Tue Jun 20, 2017 8:10 pm
James
Thanks for the info,whats the cut out on the plate for ?
PostPosted: Tue Jun 20, 2017 8:16 pm
TDC Spares Officer
That's where the clutch master cylinder normally goes.
But who needs a clutch when you have a bw!
PostPosted: Tue Jun 20, 2017 10:04 pm
The cut out is for the 3rd bolt and nut. The plate fits in a rather counter-intuitive fashion, you'd expect it to be vertical but it sits at an angle since it's purpose is not to reinforce the pedal bracket itself, but to stiffen the piece of tinfoil thick bulkhead between the pedal bracket and the wiring loom grommet hole which is where the crack appears.
I shall be using the bracket on the Dolomega, though it doesn't even HAVE a throttle cable, better to spend 10 minutes fitting the stiffener than several hours stripping out and welding up a freshly painted car!
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Wed Jun 21, 2017 8:42 am
TDC Spares Officer
My bad, combination of tiredness and heat means brains not working!
PostPosted: Wed Jun 21, 2017 9:35 am
The heats getting to me as well,
I even pm'd Alun, saying are the folds the right way :-#
PostPosted: Wed Jun 21, 2017 10:05 am
Having had the bulkhead crack myself - to the big grommet hole - I can testify to the value of this mod....
Mahesh I would have a go at the corrosion under the servo. It looks to be still treatable...but be quick.
If your insulating pad is holding water there its doing you no favours...
PostPosted: Wed Jun 21, 2017 10:10 am
Thank Jon,
I am treating the area, and will stick the pad back and put a bit of
silicone to stop any water going in from the seams, I'm even thinking
of following the bulkhead pad with silicone all around.
PostPosted: Wed Jun 21, 2017 10:30 am
TDC Spares Officer
100% agree with Jonners here, NWL's bulkhead has done exactly that, cracked to the grommet. I had the same level of corrosion under the servo of RUK, I just ground it off, treated the metal and repainted.
viewtopic.php?f=19&t=32242&start=75#p300653
PostPosted: Sat Jul 15, 2017 7:49 am
Thought I would put the pics of the brake servo cleanup on,
hopefully in the right order,
I used red rubber grease in the seams of the grommets and seals, right
or wrong ?, but not happy with the colour, thinking I should have gone
for red :)
PostPosted: Sat Jul 15, 2017 8:07 am
TDC Spares Officer
Bout time you posted an update! 8) :lol:
IMO I don't think you can go wrong with the red grease in anything rubber. If anything it will prolong the life of seals. Use sparingly though, like all grease it will attract grime and rubbish, which is why I use a dry line on my bike chain around here. :wink:
