It is currently Tue Mar 02, 2021 10:03 am
Post new topic  Reply to topic  [ 716 posts ]  Go to page Previous 144 45 46 47 48 Next
PostPosted: Wed Jan 09, 2019 12:07 pm
Hi Sam, Is that a space invaders game? It looks nice :D
It's Missile Command - an Atari game that came a few years after Space Invaders. I'm repairing/restoring the last of my collection so I can sell them on to fund an engine build for the Spitfire.
PostPosted: Wed Jan 09, 2019 12:32 pm
TDC Cheshire Area Organiser
Hi Sam, PM sent.
PostPosted: Thu Jan 10, 2019 10:53 am
PM also sent :)
PostPosted: Thu Jan 10, 2019 6:45 pm
So that's a bit of an embarrassment.... tonight she started just fine.
All I can assume is that extended cranking with too much choke led to flooding when I tried her yesterday.
Tomorrow on the way to work I'll see how the refurbed/balanced propshaft gets on at motorway speeds.
PostPosted: Fri Jan 11, 2019 8:57 am
The balanced prop seems to have cured a lot of the noise/vibration at 65mph+ but I wouldn't describe the ride as quiet.... I'll have to investigate further.
Next job is to cure the oil leaks around the pump/filter area though so she doesn't mark her territory quite so much.
PostPosted: Sun Feb 03, 2019 11:50 am
More of a running report than anything else, I changed jobs 2 weeks ago and handed back the company Vorsprung Wagen. So Binny has been pressed into service as my daily driver. 300 miles covered as a daily driver in bad weather, ice and snow.
She's got an intermittent mis-fire, sometimes pretty bad, which I think is fuel related. (I've checked the ignition side of things) I suspect she's got some muck either obstructing the fuel coming out of the tank or some grit/muck in the carbs.... I'll investigate further when time allows. (And probably investigate a fuel filter)
PostPosted: Mon Feb 04, 2019 11:40 am
TDC Spares Officer
Sam, have you checked the fuel filter inside the fuel pump, I think I put a new pump on her. DTR had the same issue and it turned out to be crap in the pump filter.
Image20180806_151825
Image20180806_152008
Image20180806_152018
PostPosted: Mon Feb 04, 2019 6:45 pm
Thanks James, I wasn't aware of the filter mesh in the pump - I'll take a look.
PostPosted: Wed Mar 27, 2019 8:43 am
Since 18th January Binny has been my daily driver. Covering just over 1000 miles since then!
Apart from the misfire (which hasn't re-occurred) no issues so far (touch wood)
I think the thermostat might have been stuck open for a while, OR she's incredibly sensitive to ambient temperature - in the cold weather she wouldn't warm up, but in the last few days she's gone promptly up to normal running temp and stayed there. I'll keep an eye on it.
Also... rebuilding the oil pump with new seals hasn't fixed the oil leak. I'll double check the torque on the pump-block bolts, but I suspect I'll need to strip the pump off again and try another o-ring. If I cure the oil leak then it'll be time for a full oil and filter change.
I took her out for a "just for fun" blast up the a-roads and motorways around work yesterday lunchtime.... what fun! It's odd having a daily driver that you just drive for the fun of it.
In the next month or so I'll probably also re-check the back brake adjustment (just to ensure that the auto adjusters are working as they should be)
PostPosted: Wed Mar 27, 2019 9:02 am
Did you change the little O rings on the oil pressure relief valve? I've seen a lot leak from there!
The rear brake self adjusters DON'T work! No matter how well set up and maintained, they just don't work! Since i've been dailying the Carledo I have to reset them every 6 months or so. But there's a built in warning system in the car, when the handbrake reaches the last click, it's time!
'72 Triumph 1500FWD in Slate Grey
PostPosted: Wed Mar 27, 2019 10:03 am
Hand brake is not great, but being an auto I just stick it in park.
Pretty sure it's leaking between the oil pump top plate and body.
I replaced all the seal/o-rings in the pump, transfer cover plate and filter assembly to try and cure the leak (including the pump relief valve)
Spitfire only has manual rear brake adjustment so I'll just treat the Dolomite the same.
 Post subject: Fuelish Mortals!
PostPosted: Fri Apr 19, 2019 4:57 pm
On Wednesday evening I swapped the fuel pump for a new one.... I've had suspicions for a while that the top on the existing one wasn't sealing properly... intermittent petrol smell... intermittent mis-fire... top of the pump "damp". On Monday and Tuesday the smell was consistently bad on the way to/from work.
The new pump looks poor - bad flashing on the casting etc, but with it fitted the "smells like a bucket of petrol" feature has gone.
PostPosted: Fri Jun 28, 2019 3:03 pm
A minor update....
Binny has covered 4200 in the last 12 months, not a huge amount but a decent amount in my opinion.
Today she passed another MOT with very little trouble, I had to replace a track-rod-end (O/S), adjust the pre-load on the front wheel bearings and tweak the rear brake adjusters. (All done prior to the test, so she passed first time!)
Not bad for her age!
PostPosted: Fri Jun 28, 2019 3:29 pm
Thats good news that Sam :D It makes mine look silly having covered just 209 miles since last August, but i did get her out today and gave her a polish to get rid of the dust and cobwebs etc :roll: But she will get a run this weekend 8) Did your towbar fit ok?
Cheers,
PostPosted: Fri Jun 28, 2019 7:01 pm
Haven't sorted the tow-bar yet. Car stuff has been on the back burner, need to sort it soon though as I need to go and collect an engine!
