It is currently Sat Apr 20, 2024 3:49 am
Post new topic  Reply to topic  [ 240 posts ]  Go to page Previous 1 2 3 4 516 Next
PostPosted: Thu Mar 07, 2019 11:05 am
Looking good Bish :D :D
PostPosted: Thu Mar 07, 2019 2:04 pm
Thanks. Hoping to be on the road this year, but still so much to do! I’m really enjoying working on VYK at the moment, he doesn’t seem to be fighting back too much. Time to work on the car is my issue.
Still on the list; fit interior, rebuild rear brakes inc brake lines, trackerjack front brakes, wax oil & under seal, solid rack mount, halogen headlights, exhaust, refurb wheels, paint satin black rear end, fit front and rear screen rubbers, various bits of chrome trim, c pillar vinyl needs gluing, rear seat belts, and plenty of other bits n bobs I’ll no doubt discover along the way............
On the road next week then! :D :roll:
PostPosted: Wed Mar 20, 2019 8:18 pm
Nice shiny new halogen headlights! As luck would have it, the previous owner had already done the halogen conversion for me, relays and all. So it was just a case of swapping the old milky lights for new ones.
One thing that had been annoying me was the aerial hole in the rear wing. I had bought a few different types, only to find that they didn’t have a steep enough angled base to fit the wing. I remembered the scuttle mounted aerial on the air cooled vws had a steep angle so I thought I’d give one of those a go.
It’s a nice fit, and stainless steel, so won’t rust before my eyes in a matter of weeks..... I hope! They are available from Machine 7. A quick google should find them if you need to.
I have also got the indicators working properly by fitting a more modern relay. I used a Meyle one because I have always found them to be good quality for the price. German quality but a bit cheaper than Hella or Bosch. Fitting one means that your indicators work all the time, even with the engine not running, and at a constant speed. Also, the relay gives a good loud - click clock sound. The only modification needed, is to fit a wire from the third pin of the relay to ground.
Incidentally I have a few of these relays surplus, so if anyone wants one drop me a pm.
PostPosted: Mon May 20, 2019 6:03 pm
Keeping the thread going there’s nothing too exciting to report, only that I have been under the Sprint giving it a good coat of underseal and cavity wax. Not pretty but hopefully will keep the rust at bay for a bit. The rear brakes have been rebuilt, the prop is back on, and I’ve been wrestling with the rimmers stainless exhaust. It is proving to be a bit of a pain as it wasn’t fitted very well in the first place, but it will be fitted better this time around!
I’ve whipped the cam cover off and re torqued the head. Good news is that the plug tubes look to be new items that are in good condition, maybe they are club ones? Everything looks to be in order so I’ll leave well alone for now. The cam cover gasket had been stuck on by the PO so that was a bit of a burger to get off, but I’ve got the mating surfaces nice and flat with a block and emery cloth. I have the clubs stainless allen screws for when it goes back together so fingers crossed for a leak free cam cover.
Time to test the image hosting site;
Oooooooh it works :thumbsup:
PostPosted: Sun Jun 02, 2019 5:48 pm
Fitted up the rear brake pipes today plus the load sensing valve and goodridge braided hose. Looking for guidance on fitting the braided hose on the forum - it seems there has been some confusion on how the goodridge hose fits. I think that I have it on correctly after looking at the fittings supplied for a while. Photo shows the correct way (I think). It’s laid out so that, as you look at the photo, the copper pipe fits up to the left and the right side is the load sensing valve end. Looking at the concave and convex ends helped me make up my mind on this, it seems to me that this is the only way to go. Time will tell when I get some fluid in and bleed the system.
Plenty of black underseal has been applied, not a pretty finish, but looks tidier than it did for sure, and hopefully will keep the rust at bay.
Got VYK up and running again, but I’m not sure if the top end is a bit noisy? Click the link for a video;
https://vimeo.com/339842462
PostPosted: Sat Jun 08, 2019 11:57 pm
Had a good day today working on the front brakes. Started with this not so pretty sight:
Ive got both sides stripped out of the old set up, and the off side mocked up with the new, to see how everything with the trackerjack conversion goes together whilst checking for clearances etc before painting and final fit up.
I’m impressed with the kit supplied by Jon trackerjack, it all went together nicely with no problems. Well done Jon, good work mate!
Jon supplied; discs, clamp rings, caliper mounting brackets, bolts, and spacers. I found a decent pair of calipers and carriers, which came from a scrapped 1989 diesel Ford Escort estate on eBay. All in nice working condition - good seals, no seized bleed nipples - for £30.
So all in all, it’s cost very similar money to renewing all my original seized set up. Bargain I reckon. :thumbsup:
PostPosted: Wed Jun 26, 2019 6:37 pm
Trackerjack brakes are done. Fresh brake fluid in and all bled through nicely. I used Goodridge hoses to replace the originals, and then made my own braided hoses to extend to the caliper using fittings and hose from car builder solutions.
The photos aren’t great as usual, it’s a bit tight in the garage to get a decent shot!
:thumbsup:
PostPosted: Tue Jul 02, 2019 6:48 pm
As the weather has been nice and warm I took the opportunity to do a bit of painting. I used rattle cans from Halfords which I have always found to be of a decent quality, second only to aerosols from specialist car paint retailers. I pondered for a bit on wether to paint the sills satin black, as they were originally, or in body colour. I decided on body colour as I prefer that look. The Russet brown paint from Halfords turned out to be a good match for my car. I suspect my car has been painted on the exterior with the MG Russet brown as the rattle cans are said to match that. The interior paint is original to the car and a very slightly darker shade.
Also tidied the rear end up with a few coats of satin black.
Looking forward to fitting some nice new badges that I have in stock to replace the faded originals.
:thumbsup:
PostPosted: Tue Jul 02, 2019 9:19 pm
Great thread this Bish, I am enjoying reading your posts.
Not easy in a single garage, I struggle in mine although you do realise how narrow a Dolly is compared to a modern car.
Storing parts is a problem too, especially the interior!
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
PostPosted: Wed Jul 03, 2019 3:52 pm
Looking good! Tracker jack brakes are a must, if only to see the look of shock on the tester's face when you go for the MOT.
PostPosted: Thu Jul 04, 2019 1:38 am
Thanks Matt. I’m enjoying your thread too. Showing some skill with the welder! I wondered why you weren’t fitting the sills yourself, but I guess if you’ve the same sort of amount of space as me in the garage then it would be too awkward?
PostPosted: Thu Jul 04, 2019 1:41 am
Thanks. I’m looking forward to mot time. My friendly local mot tester is a classic ford escort man (pah!) and usually ribs me about my cars. I’m thinking he may actually like this one though.
PostPosted: Thu Jul 04, 2019 2:14 pm
Cheers! Yes, I probably should have bit the bullet and fitted them myself. As you say, space is a bit tight, but I just wanted to know that the structural side was properly done....
Regards
MC
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
PostPosted: Thu Jul 04, 2019 4:57 pm
Hi Matt and Bish, i am enjoying both your threads 8) It's great to see our cars come together :D Keep up the good work both.
PostPosted: Thu Jul 04, 2019 8:49 pm
Thanks Tony :thumbsup:
Users browsing this forum: Bing and 126 guests
