It is currently Wed Oct 16, 2019 12:58 pm
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: uprated head
PostPosted: Sun Jan 23, 2011 9:54 pm
I have an uprated cylinder head i got a couple of years ago i want to use in my leyland st replica i am building ,it has dropped a valve and another one is bent.I need to identify the origin of the head to get new valves.I have looked at the valves and they are different from standard valves as the collets fit a bit lower on shaft and the diameter of shaft is slightly smaller,it also has alloy cups on top of springs.we think it might be a sprintspares head,the guy i got it off paid £400 new for head,on the end of the cam is stamped 16vt 145 and punched on head various times is so3 6qn,no on end of exhaust valve is 10135 mi.any advise or info on this would be greatfully recieved
 Post subject: Re: uprated head
PostPosted: Sun Jan 23, 2011 11:34 pm
Hi Andy the number T145 is triumphtune ref to their STR091 replica cam.
PostPosted: Mon Jan 24, 2011 8:44 am
Sounds like you have a cam reprofiled from a standard cam therefore machined down on the base circle to get the lift. Longer valves are then installed to take up the gap caused by reducing the base circle of the cam.
Regards.
Dolly Sprint racer 33
81 Dolly Sprint.
TWR Group A Rover Ch no 002 Hepolite.
4 other Sprints mostly for spares
Rover Tomcat race car.
Lotus Elan + 2S
Mitsubishi Legnum.
BMW E46 M3 convertible.
Rover Vitesse SD1 4500 Twin plenum.
Rover Vitesse SD1 twin plenum
Rover Vitesse SD1 twin plenum.
Rover SD1 2000
Rover Vitesse 820 turbo coupe.
Rover SD1 4200 pick up.
MG TF 160 VVC.
MG Express van 160 VVC.
BMW E30 325i Touring.
BMW E12 M535i.
Lotus Cortina Convertible.
E type Jaguar series 1.
Triumph Stag.
MGB Roadster.
VW Transporter Kombi Sportline.
VW Touareg R line
Capri 3.0 Ghia.
Cortina Savage estate.
Chevrolet 28ft camper.
Morris Minor Traveller.
Nissan Navara.
Mercedes 814.
Suzuki 125 Van Van.
+ many more.
PostPosted: Mon Jan 24, 2011 7:02 pm
thanks guys looked up the thread on valve clearances identifying cam as a sprint cam.would a good engine parts supplier be able to get valves if had numbers.
PostPosted: Mon Jan 24, 2011 11:17 pm
I know that Burtons Ford tuning guide gives all dimensions for their valves so might be able to match some up, then you can have some good old Ford reliability :lol:
PostPosted: Thu Jan 27, 2011 7:44 am
Hi, If you do rebuild the head, throw the alloy caps away. I have had an instance of the valves pulling through alloy caps. I have never had any problems with standard caps.
Regds Grelley
PostPosted: Thu Jan 27, 2011 9:28 am
Did you buy that head of a bloke called Derek near Guildford? He acquired the spares package that originally went with my nitrous Sprint before I bought the car and that sounds very much like the head that the PO had to take off shortly before I bought it! Strangely on the journey home it dropped another valve :roll:
PostPosted: Fri Jan 28, 2011 8:47 pm
thanks guys for your response,i bought the head from some one in ivybridge devon about 2 yrs ago with some 45s and a manifold.after a few phone calls i have located some valves at b.k.t.
PostPosted: Sun Jan 30, 2011 12:14 am
Tell him at B.K.T that you have my brakes fitted and he will tell you they are death traps and beware (thats why he wanted to sell them himself) :lol:
Please mention my name and you will get a poke in the eye from him :lol:
Be warned Andy :wink:
