It is currently Tue Apr 16, 2024 11:42 am
 Post subject: The Digital Dolomite
PostPosted: Sun Jul 25, 2021 8:19 pm
Hi All
Something I thought might be a nice idea to start but it might already either been done or in the works is to maybe create a kind of digital Dolomite. basically making some bits and pieces virtually that any forum member could access and a reasonably competent person could manufacture them either from original style materials or from modern style materials. If other people want to contribute sketches, drawings, or files, they can be added as well.
It’s just something that I’d be working on in my spare time. I’ve already done a handful of components that are 95% the way there (just due to manufacturing tolerances of BL make the last 5% hard), but accurate enough that someone could make it. Could either be used to help someone repair their components or build something from scratch that isn’t easily available.
The main items I’m thinking of are like; carpets, door cards, boot trim, dashboard wood panels, door trim, etc. Things that can be made without the use of a several-tonne press or complex machines.
I can start, I just spent a good few hours modelling up the under-dash parcel shelf, just as it was in the garage, and the front uprights. The uprights aren’t something someone could make but its to help me work on something else more interesting 😏
Edit: added sketch of the parcel shelf
Parcel Shelf - Front.pdf [98.53 KiB]
Downloaded 8 times
Last edited by Boost All The Dollys on Fri Oct 01, 2021 3:01 pm, edited 2 times in total.
 Post subject: Re: A Digital Dolomite
PostPosted: Sun Jul 25, 2021 8:37 pm
Good idea , Carpet sets and door cards you can get from aldridge, some one on posted a drawing of the parcel shelf
PostPosted: Wed Sep 22, 2021 6:46 pm
Another obsolete part modelled!
This time it’s the Sprint Grill. Took a good while to sort this one out but now you can take it and have a pair 3D Printed! Or if you want to make your own custom grill, just hollow it out.
You could also take sections of this and make it out of a flat sheet of plastic like a wooden model if your brave enough
The STL files are attached so they can be imported into whatever software. Maybe the Club could get someone to make a batch
Sprint Grill.zip [291.12 KiB]
Downloaded 6 times
PostPosted: Wed Sep 22, 2021 8:59 pm
Excellent work. Unfortunately my printer isn't big enough. Have you included the holes for the fixings?
1997 TVR Chimaera 450
PostPosted: Wed Sep 22, 2021 10:42 pm
Yes! I have. It’s not 100% accurate to a stock grill as the originals have a very slight taper to all the vertical surfaces for help getting it out of the moulds. I haven’t recreated this as if printed it doesn’t need it and it’s added complication for no real benefit.
In theory, you can split the grill in half and print it out in two parts and glue/melt them together.
What printer do you have? I’ll have a go tomorrow breaking it up into suitable chunks for you. I’m hopefully going to get a resin printer in the next few months which should give a smooth, stock like surface finish.
PostPosted: Fri Oct 01, 2021 3:13 pm
an update just for you, Mart.
Finally got some free time this week and sorted it all out. I’ve split each grill into two separate parts, both within the bounds of a Creality Ender 3 (I’ve assumed that this is what you’ve got, it’s a pretty popular model)
I’ve also gotten the Early 1300/1500 grill done! They’ve also been split into two parts for printing.
Early 1300-1500 Grills (Divided).zip [40.5 KiB]
Downloaded 10 times
Sprint+1850 Grill (Divided).zip [105.86 KiB]
Downloaded 9 times
 Post subject: Re: The Digital Dolomite
PostPosted: Fri Oct 01, 2021 4:46 pm
Thank you.
Yes I have an Ender 3v2. I sliced one section in Cura and it will take 1 Day 16 Hours to print. So I think I'll give that a miss, unless someone pays me lots of money to print a set! :lol:
But a great effort from you. :thumbsup:
PostPosted: Thu Oct 07, 2021 11:57 am
Digitisation is a great idea! Great effort mate..:thumbsup:
PostPosted: Thu Oct 07, 2021 12:07 pm
Yeah, I’m just trying to make sure that some of the less commercially viable parts are still available to the people who enjoy Dolomites.
Im trying to stick to the plastics and wooden parts for now so that they can be either 3D printed or easily made in single batches. If anyone else wants to join in it would be appreciated, even if you just make a quick sketch, I can try and make files and parts in my spare time.
PostPosted: Tue Oct 12, 2021 2:32 pm
Something not existing but thought it might be useful
Low profile bell-mouths for the different size SU carbs. Only 10mm tall so might not have a massive increase but will help with airflow slightly.
There’s nothing stopping you from making them longer if you wanted to.
Low Profile Bell Mouths.zip [31.26 KiB]
Downloaded 3 times
PostPosted: Tue Oct 12, 2021 10:14 pm
You could try the plastic clip/bush which is the lower pivot for the front quarter window. These are nearly always cracked or broken and are NLA.
PostPosted: Tue Oct 12, 2021 10:28 pm
I’ll have a look, I’m mainly focusing on parts I’m taking off my car to work on it, but I’ll try and get it out next time I’m working.
But yes! This is what I mean, if there’s any parts that just aren’t available, I’ll try and get one so the community can create them
Users browsing this forum: Bing and 11 guests
