Hello there.
I'm a brand new owner of a 1500 FWD (1972), and I'm brand new to owning a classic car!
I have a persistent and irritating starting problem at the moment and wondered if anyone had any good ideas.
I had a new battery fitted and she was fine for a week, but now she refuses to start unless jump-started. The engine cranks and sounds like it turns over once, slowly, the dash lights dim, and then nothing. Headlights etc come on fine. If you jump start her then she goes every time straight away and runs fine.
My current suspicion is the starter motor (which has been given a judicious whack or two), rather than the battery (which is only a week and half old), though it's possible that the alternator isn't charging the battery properly (not really had her long enough, or been far enough, to work that one out). Not sure where the voltmeter ought to be sitting under normal conditions.
Any tips for where to start, similar problems encountered? Hope I'm not just being dense!
