Hi
No problem with the hijack! Firstly the foolish admission. I leant my timing light to someone about 2 years ago and could remember who (Foolish act no 1). I eventually found out and retrieved said item. I had timed the car up using some basic techniques and when I put the light on it, found it was firing somewhere near 30 degrees before! I'm amazed it ran. Needless to say, at 10 it is much a different car!
I've only done some basic checks on the chain and mine looks to be ok, but I did do some research and there is a racing timing chain tensioner which overcomes the issue:
http://www.bighealey.co.uk/content/hydr ... ensioner-0
Weather this will ever solve the problem, I'm not sure. Part of the issue is the chain is so long to start with! Heaven knows what a stag one is like (and a not a duplex chain). Anyone got any contacts in the SOC to see what their solution is?
I think I do have a slightly rogue follower, but that will be sorted out in due course. I did order a new oil pump, even though I have no clue what the oil pressure is as, guess what, I leant my oil pressure gauge to someone! My thoughts were that for £50 its done, even though I would hope that it was changed when the engine was rebuilt. Who knows.
Back to the tensioner debate and the jackshaft, I think a thrust device would help. I know they should run in line, but the thrust set up on the jackshaft is hardly brilliant and the backlash of the gears, I do wonder if that contributes to the issue.
Thanks to everyone for their help and will let you know what I find.
Fitting vinyl roof this afternoon! Its odd, I gave up working in a bodyshop years ago for the' desirable Insurance Engineer' job and look what I do at weekends! My sheerline is looking very envious at the sprint for all the attention its getting!
