It is currently Fri Apr 19, 2019 6:57 pm
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: Mon Feb 08, 2016 9:58 pm
Right, time to return to this now that various other 'projects' have departed. Quick question for the moment: where/who is recommended please for the requisite Payen gasket set. Thanks.
Regards.
Brompton P-Type, 2008
Moulton APB R18, 200x
Bat-eared Jack Russell, year unknown
Blog: www.ymgw.blogspot.com
PostPosted: Tue Feb 09, 2016 6:28 am
http://www.jamespaddock.co.uk/parts.asp ... ehicleId=2
As an aside, while the head is off is an ideal time to give the exhaust manifold and downpipe a little attention. I use a file to make sure both are flat on their mating face. (and consider replacing the studs if they are bad. I had a broken one and 2 manky ones, so drilled out and tapped to 10mm, which causes a small issue that the new gasket needs carefully opening up, and really cap head bolts to replace the studs. But no more blowing gaskets!)
PostPosted: Tue Feb 09, 2016 12:41 pm
TDC West Yorks Area Organiser
I'd like to add that the downpipe should be bolted to the gearbox bracket as well. This will help to prevent the manifold/downpipe joint from leaking and it will stop the exhaust from banging against the chassis rail.
Meetings take place on the first Wednesday of the month at 8.00pm at The Britannia, 239 Swinnow Rd, Pudsey, LS28 9AP.
1972 Dolomite 1850 auto (NYE 751L - The rolling restoration)
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the modern)
1995 BMW 318i (M265 PNC - Project Bimmer)
2004 Vauxhall Corsa Design 16V (FE04 FKG - not mine! Being revived)
"There is only one way to avoid criticsm: do nothing, say nothing and be nothing." Aristotle
PostPosted: Sat Feb 02, 2019 10:51 am
I recently purchased this car from Richard and am working through this job (helped by the replies above). Having got the head off and had it cleaned etc, I'm unsure as to whether I should buy new studs, washers, nuts for the block and head or just cleaning the originals should be fine?
Stephen
PostPosted: Sat Feb 02, 2019 3:05 pm
Some new head nuts is always a good idea. Unless the studs are noticeably devoid of thread, they should be fine, just give them a clean up and a film of light oil.
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Sat Feb 02, 2019 4:02 pm
Cheers Steve, will do.
Thanks also for the recommendation of Head Technique - picked it up yesterday but looks so good to put the rest of the car to shame!
Stephen
PostPosted: Sun Feb 03, 2019 11:00 am
Online
Maybe not everyone's opinion.... but if you can re-use head studs and they are in good condition do so. If you are short of a couple I might have some in a box somewhere you can have.
If they are not re-usable (and you can't get some old ones in good condition) then consider an ARP kit. They are expensive, but worth it.
Personally I'm not sure how much I''d trust new replacements from anyone other than ARP. Most probably it's my paranoia and they'd be fine.
PostPosted: Sun Feb 03, 2019 11:48 am
if buying new nuts/washers you MUST NOT use std nuts or washers. They need to be specific head nuts and hardened washers. Otherwise you will be doing the gasket again shortly....
Canley classics are a good source of OHV stuff.
Oh, and I have always reused the studs/nuts/washers unless damaged.
PostPosted: Mon Feb 04, 2019 11:17 am
Our local friends at Fitchetts also have the correct head nuts in stock.
PostPosted: Mon Feb 04, 2019 11:29 am
I am learning something new almost every week on this discussion board. What is special about head nuts and washers?
PostPosted: Mon Feb 04, 2019 4:45 pm
I think there or should be high tensile steel
PostPosted: Sun Mar 03, 2019 11:25 am
I've fitted most of the engine and ancillaries back together now but can't seem to see the block drain that was mentioned (or at least what I was expecting). Is this usually a tap or a brass or similar plug?
Stephen
PostPosted: Sun Mar 03, 2019 4:12 pm
Online
I think on the 1500 block it's the "open" hole in the group of three "knobbles" shown here bottom left.
Certainly on the later engines/cars it's just a hex head plug not a tap.
Dunno why images on postimg seem broken.... try something else....
I yoinked an image out of google image search...
PostPosted: Mon Mar 04, 2019 6:46 am
Thank you - easily spotted with that picture to help!
PostPosted: Tue Mar 05, 2019 12:58 pm
A good poke about in the hole with wire is often required as they can be so badly blocked up....
In fact I strongly recommend flushing the block, I push a garden hose, cut off dead square, against the drain hole. Obviously need to have another hose off somewhere, otherwise you will get very wet. And flushing the heater matrix is a fine idea while you are at it. Both ways, several times.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], yorkshire_spam and 5 guests
