It is currently Wed Mar 20, 2019 5:12 pm
 Post subject: Chassis plate stamping
PostPosted: Fri Jul 31, 2015 9:06 am
On another note, I want to get a new chassis plate as mine has been stamped badly. Does anyone do the stamping so it looks nice? I dont want to choose the wrong size/font or hammer them too hard that its like braille on the back. What do folks do with them ?
PostPosted: Fri Jul 31, 2015 9:26 am
I have a set of number and letter stamps Tony, they aren't exact to OE, but then you see a variety of shapes and sizes on the cars, particularly between old style and later style chassis plates.
PostPosted: Fri Jul 31, 2015 9:35 am
When you get a chance Alun could you measure the height and width of a couple of letters/numbers for me? Ive got some stamps too so if they are close to the same I might try mine.
Maybe a zero and an I would be a start?
PostPosted: Fri Jul 31, 2015 10:40 am
What about those jewelry bracelet engravers?
Mayne worth a try...
PostPosted: Fri Jul 31, 2015 10:57 am
Yes someone else suggested that too. If I had the rough size of the numbers they may do a neater job than me.
PostPosted: Fri Jul 31, 2015 8:48 pm
Bill ate Rarebits offers a stamped commission plate service, and knowing Bill it will be correct. May be worth an email?
PostPosted: Fri Jul 31, 2015 8:53 pm
thanks Clive i never knew that. Ill try him first
PostPosted: Fri Jul 31, 2015 9:22 pm
Meanwhile, I'll measure mine tomorrow...
PostPosted: Sat Aug 01, 2015 5:32 pm
Thanks Alun, I havent been on today car trouble grrrr . First legal day on the road and it decides to fuel starve so tank check for debris is my first joyful task tomorrow. :evil:
I knew I should have put a modern set up in there to get some confidence.....
PostPosted: Mon Aug 03, 2015 8:35 pm
Looking at mine I think they are 3/16ths wide or 4.7 mm, nearest nowadays is 5mm.
Malc
PostPosted: Tue Aug 04, 2015 8:26 am
Thanks Malc, what number did you measure?
PostPosted: Tue Aug 04, 2015 10:03 am
Tony,
most of the characters are the same height and width with the exception of 1, I but all the others are the same width.
hope this helps
Malcolm
PostPosted: Tue Aug 04, 2015 11:16 am
ok thank you :)
PostPosted: Tue Jun 05, 2018 2:33 pm
He will only stamp plates he has supplied. (or at least that's what he said on the CT forum a while ago)
Users browsing this forum: No registered users and 6 guests
