Flywheel Plate
series111
Flywheel Plate
#1 Post by series111 »
Hi All :bluewave:
Same old thing I know this thread has been done before but can't find it, on a Dolomite sprint which way round does the plate which the bolts go through on the flywheel go round in to the spigot bearing or out to the clutch.
Thanks Dave.
Flyfisherman
Re: Flywheel Plate
#2 Post by Flyfisherman »
series111 wrote:Hi All :bluewave:
Thanks Dave.
flat side facing the clutch plate / gearbox the raised section is to hold that brass spigot sleeve in the crank in place
Flyfisherman
Re: Flywheel Plate
#3 Post by Flyfisherman »
Thanks Dave.
See attached: viewtopic.php?f=4&t=27610&hilit=clutch+ ... 15#p269850
Re: Flywheel Plate
#4 Post by tony g »
Yes dimple inwards to hold the spigot bush in situ (theyre never that tight and Triumph probably added the dimple instead of fixing the clearance issue)
series111
Re: Flywheel Plate
#5 Post by series111 »
That's great thanks for your replies
