I just came across this old post and thought it might be worth adding the BL Technical Bulletin for when they were fitted on the TR7s.
They were brought in to avoid squeal problems with the phosphor bronze ones and fitted on production to all later cars.
Refarding which way round they should go, there is a seal incorporated in the bearing which should be facing the gearbox.
Looking at my photos again, the seal appears to be at the flat end, in which case I have put it in the wrong way round. Oh well, its been no trouble so far...
