Wiring diagram http://forum.triumphdolomite.co.uk/viewtopic.php?t=34168 |
Page 1 of 1 |
Author: | new to this [ Mon Jul 09, 2018 8:08 pm ] |
Post subject: | Wiring diagram |
there's two fuses in a dolomite, is one permit 12volt and the other ignition supply , also for the heated rear window should there be a relay Thanks Dave |
Author: | soe8m [ Mon Jul 09, 2018 8:24 pm ] |
Post subject: | Re: Wiring diagram |
Dolomites don't do relay's. Pure good old amps through the switches. Jeroen |
Author: | Mad Mart [ Mon Jul 09, 2018 8:39 pm ] |
Yes, one is permanent the other is through the ignition switch. There should be relays on a lot or circuits...but there wasn't from the factory. |
Author: | new to this [ Mon Jul 09, 2018 8:44 pm ] |
Thanks Mart and Jeroen Dave |
Author: | Mahesh [ Mon Jul 09, 2018 8:49 pm ] |
Relays need more cabling and cause connecting confusion on the assembly line, thus a reason to strike, easier to buy high amperage expensive dc switches. |
Author: | GTS290N [ Mon Jul 09, 2018 8:51 pm ] |
And when things go wrong a fire means a new car. Good marketing strategy.
Author: | Galileo [ Mon Jul 09, 2018 11:31 pm ] |
I still think of relays as a novelty, and I'm not that old, as all the cars I had growing up never had relays or if they did it was just the one like for the horn. Mr Lucas has been a tad unjustly maligned, just as with any other, at the time ubiquitous, mass producer of product they build and deliver to a cost. Could be worse, like the Magneti Marelli stuff I've encountered in years gone past! |
Author: | soe8m [ Tue Jul 10, 2018 10:27 am ] |
It's very hard to make exact reproductions of Italian harnesses. It's almost unnatural to fabricate because I'm always tempted to improve because that's so easy to do. Jeroen |
