Make sure you have the correct coil and measure the amps go through. Lumenition optronic or magnetronic last forever. The ones that fail, fail because the installers don't read the instructions properly or have no clue of different coils.
A lumenition needs 3Ohm primairy resistance, so a 3Ohm std unballasted coil or a 1,5Ohm ballasted coil together with a 1,5Ohm resistor. Sometimes the coil, like the Bosch ballasted ones are 1,2 Ohm you need a matching 1,8Ohm resistor.
Easy maths. 12v/3Ohm= 4 amp. 12v/1,5Ohm is 8 amp.
8 amp is for many electronic kits too much to switch so they fail very soon.
It's easy to measure with a multimeter how much amps is drawn through and then you know you have the correct parts fitted to enjoy endless of your lumenition or that it only will last 5 miles.
You can also fit a 4 amp bladefuse in the lead that connects to the coil minus to 'save' your electronic ignition kit.
An 123 ignition can switch about 12 amps and will work at almost any coil and setup and is made in NL.
Classic Kabelboom Company. For all your wiring needs.
http://www.classickabelboomcompany.com
