It is currently Sat Dec 15, 2018 2:29 am
PostPosted: Thu Nov 15, 2018 3:25 pm
Hello all
I’m looking for any advice or tips for fitting the gearbox front oil seal. As you can see from the picture I have managed to crack the end cover whilst attempting to drift the seal in with a socket.
Maybe I’m a bit heavy handed, but maybe the seal is a bit oversized? Could I put the end cover in the freezer? Should this seal be a simple push fit?
Anyway, I have managed the find another end cover so any help would be appreciated in the hope that I don’t bugger it up again!
All the best, Bish.
PostPosted: Thu Nov 15, 2018 3:52 pm
Freezer will make the hole smaller so you dont want that. Better to heat the cover to about 120C and get a socket or press tool that sits inside the seal and gently tap it in. Bit of grease around the seal too. Ive never had to heat the cover but I have press tools to do the job.
 Post subject: Well.....
PostPosted: Thu Nov 15, 2018 4:02 pm
I leave the seal in oil overnight before fitting.
(I do this for crankshaft spigot bushes too.)
PostPosted: Thu Nov 15, 2018 5:38 pm
TDC Cheshire Area Organiser
What i used to do was to use the old seal upside down, so effectively pushing two seals in. That way you dont damage the new seal. If the old seal grips when its gone in, just flick it out.... No damage to the new one.
It looks as though the socket you used was a tad oversized?
PostPosted: Fri Nov 16, 2018 3:05 am
Wise words all, thanks for that.
I need to be a bit more patient for sure. And perhaps that socket was too big. I was trying to push the seal in using the outer lip, but now I see it would be better for the socket to sit inside the seal driving the face of it. I’ll try some heat and a little grease or oil too. Why I thought the freezer was a good idea I don’t know!?
Thanks again.
PostPosted: Fri Nov 16, 2018 8:58 am
You were right to use the outer lip. If you use a socket inside you will ruin the seal.
2007 Porsche Boxster S
Grammar:
Schedule: Pronounced "Shedule" not "Scedule"!
Users browsing this forum: No registered users and 13 guests
