POWER STEERING
- TDC Editor
POWER STEERING
Having run Dolomites / FWDs since 1987 age is catching up with me and I find my Dolly SE a great car but a bit too heavy on the steering at parking speeds. So I have decided to have an "Easysteer" power assisted unit fitted. The firm has an extensive web site and is based in Bolton, so not too far from me here in Leeds. They sent me some pictures of a Dolomite fitted with their unit, it sits nicely at head of column just above the parcel shelf. I was concerned as to where the unit would be fitted - little room in engine bay due to large servo unit.
They charge £800 to supply and fit, which seems quite reasonable. Another system costs in excess of £1500 - I mentioned it in Dolly Mixture.
The pictures they sent were of an Auto Dolly, is the owner a club member or reader of this forum? Has anyone else had such a unit fitted?
Re: POWER STEERING
Hieveshamcroft wrote: ↑Sun Jan 27, 2019 12:15 pm Having run Dolomites / FWDs since 1987 age is catching up with me and I find my Dolly SE a great car but a bit too heavy on the steering at parking speeds. So I have decided to have an "Easysteer" power assisted unit fitted. The firm has an extensive web site and is based in Bolton, so not too far from me here in Leeds. They sent me some pictures of a Dolomite fitted with their unit, it sits nicely at head of column just above the parcel shelf. I was concerned as to where the unit would be fitted - little room in engine bay due to large servo unit.
Do you know what it would cost just to supply ?
- Site Admin
Re: POWER STEERING
It'll tell you on their website; http://simonebirchall.co.uk/shop.html
Re: POWER STEERING
Interesting, I have seen that company but didn't know they did Dolly systems.
You have checked that your current steering system is working properly? While converting my 1500 to a Sprint I took off the steering rack and found the knuckle joint (think that is the name of it ) was frozen and needed freeing. I believe that can make the steering heavy.
Re: POWER STEERING
I would second checking things out first. When I got mine the steering was very heavy but after lubricating the knuckle joints and greasing the rack it was much easier on the arms. Keeping the rack well greased and re doing the joint regularly keeps it that way. I recently put on new track rod ends, they had passed the MOT but had an advisory for the rubbers and I ended up putting on new greaseable ones. It surprised me how much of a difference that made also.
Re: POWER STEERING
Some good pictures on their website showing the unit and the slightly modified parcel shelf. Looks better than the corsa version which is much lower down the shaft.
Re: POWER STEERING
I don't think I have ever come across ball-joints for outboard track-rod ends with a greasing facility (i.e. grease nipples). Do you have any more information about these?RobSun wrote: ↑Mon Jan 28, 2019 12:56 pm Steve
Regards.
Nigel A. Skeet
Nigel A. Skeet
Re: POWER STEERING
The last dolomite that I purchased has stiff steering and on investigating I found that one, of what looks like a relatively new lower suspension ball joint, part number GSJ 135 or GSJ 136 is very tight. I am hoping that it will free up with use.
I disconnected the track rod ends to find out where the stiffness was within the steering system as it is quite easy to split them.
- shaunroche
Re: POWER STEERING
I have had exactly this situation and unfortunately in my experience it just gets worse, so they want changing really!Richard the old one wrote: ↑Wed Feb 06, 2019 5:24 pm lower suspension ball joint, part number GSJ 135 or GSJ 136 is very tight. I am hoping that it will free up with use.
Re: POWER STEERING
Are these the items to which you refer:naskeet wrote: ↑Wed Feb 06, 2019 4:44 pmI don't think I have ever come across ball-joints for outboard track-rod ends with a greasing facility (i.e. grease nipples). Do you have any more information about these?RobSun wrote: ↑Mon Jan 28, 2019 12:56 pm Steve
Track-rod end GSJ156 with grease nipple
GSJ156 Triumph High Quality Track Rod End With Grease Nipple 2000 2.5 Tr5 Tr6 - £8.45 - Free postage
https://www.ebay.co.uk/p/GSJ156-Triumph ... 2405349665
Regards.
Nigel A. Skeet
Nigel A. Skeet
Re: POWER STEERING
I don't know what the part no. Is, my local classic car garage got them probably from Moss as their round the corner from him. Recommended them and he fits them where he can. He has a knack of knowing what parts can be used on cars that they are not listed for but fit perfectly. The ones in the picture look the same but I couldn't confirm if they would fit. I will pop over to see him in the next few days and see if I can get the part no. off him or what car they are meant for. I know he has fitted parts for tr4 or 6 on mine that are identical but not listed as being so.
- Site Admin
Re: POWER STEERING
I've recently had ALL my car's steering components replaced and on the move, the steering is great. However, at parking speeds, the steering is hugely heavier than that of a modern, PAS-equipped car. This is why the original poster in this topic is thinking of having his car fitted with PAS.
Re: POWER STEERING
In addition to the steering rack, I have always regularly greased the top steering swivels and later the propeller-shaft universal-joints, once I discovered they had blanking plugs which could be replaced by grease nipples.RobSun wrote: ↑Thu Feb 07, 2019 8:13 pm Are these the items to which you refer
I wonder whether bottom steering swivels with greasing points are also available for the Triumph Toledo & Dolomite!?!
Apart from driving a 2004 SEAT Leon Cupra 20V Turbo for 1 mile only (the most modern car I have driven), the only other car I have driven with power-assisted steering, was my father's 1986 Ford Sierra XR4x4 (the next most modern car I have ever driven).triumphdolomiteuk wrote: ↑Thu Feb 07, 2019 9:36 pm I've recently had ALL my car's steering components replaced and on the move, the steering is great. However, at parking speeds, the steering is hugely heavier than that of a modern, PAS-equipped car. This is why the original poster in this topic is thinking of having his car fitted with PAS.
The 23 feet long, Ford truck-based motorhome that I drove in California in September 1981, had horribly-weighted power-assisted steering, which enabled one to virtually turn the steering wheel with one hand when the vehicle was stationary.
Regards.
Nigel A. Skeet
Nigel A. Skeet
Re: POWER STEERING
Sorry for the delay in getting back regarding greaseable track rod ends. I am advised they are for the MG Midget so could possibly be the ones shown although the Midget is not listed on the specs. They were supplied by my local classic garage and I believe they got them from Moss.naskeet wrote: ↑Thu Feb 07, 2019 4:47 pmAre these the items to which you refer:naskeet wrote: ↑Wed Feb 06, 2019 4:44 pmI don't think I have ever come across ball-joints for outboard track-rod ends with a greasing facility (i.e. grease nipples). Do you have any more information about these?RobSun wrote: ↑Mon Jan 28, 2019 12:56 pm Steve
Re: POWER STEERING
Here is the link to more appropriate track-rod end ball joints with grease nipples, for the Triumph 1300, 1500, Toledo & Dolomite, from Classic Parts Trader:
2 x TRIUMPH 1300, 1500 (FWD & RWD), DOLOMITE, TOLEDO REGREASABLE TRACK ROD ENDS
https://www.ebay.co.uk/itm/371256879302 ... Swl51hL7Sp
Price: £12.99
Ian Farrington-Smith
50 Beaufort Avenue
Leamington Spa
Warwickshire
CV32 7TB
United Kingdom
Phone:07722828427
Email:ianfs13@gmail.com
Price: £12.99
50 Beaufort Avenue
Leamington Spa
Warwickshire
CV32 7TB
United Kingdom
Phone:07722828427
Regards.
Nigel A. Skeet
Nigel A. Skeet
