Where is/are the drain for the heater intake? http://forum.triumphdolomite.co.uk/viewtopic.php?t=34707 |
Page 1 of 1 |
Author: | Bumpa [ Wed Feb 06, 2019 4:09 pm ] | ||
Post subject: | Where is/are the drain for the heater intake? | ||
I can't see any sort of outlet for water that collects there. In my photo, is the drain somewhere under the speedo cable or nearer to the heater pipe?
Author: | mahony [ Wed Feb 06, 2019 5:04 pm ] |
Post subject: | Re: Where is/are the drain for the heater intake? |
There are several small holes which drain the water away at the bottom of where your pool of water is, you need to get a wire coat hanger or similar to unblock your holes and then remove as much muck as you can |
Author: | Awaiting Repair [ Wed Feb 06, 2019 7:26 pm ] |
Have a look here........ https://forum.triumphdolomite.co.uk/vie ... hp?t=16792 I would use something made from plastic to poke them out. Cheers Keith |
Author: | Toledo Man [ Wed Feb 06, 2019 11:13 pm ] |
Such as a cable tie perhaps? |
Author: | Bumpa [ Thu Feb 07, 2019 9:41 am ] |
Thanks for the link to that article Keith. I shall have to get a cable tie and have a go! |
Author: | tamtrucks [ Thu Feb 07, 2019 11:10 am ] |
i use air line and a hoover for those drainage holes/passages,work wonders |
