Help: Bits of Sprint to identify
http://forum.triumphdolomite.co.uk/viewtopic.php?f=4&t=34838
Author:  GrahamFountain [ Thu Mar 28, 2019 9:13 pm ]
Post subject:  Help: Bits of Sprint to identify
I got a bag of bits with the car from the painter, some of which look like they might matter - it drives, there's just little in the way of lights yet.
Can anyone help identify any of these? The bits on the right just look like yer average load of nuts, bolts, screws, and washers, but some of the bits on the left may be recognizable I think.
Here's another view:
Author:  Len Hughes [ Thu Mar 28, 2019 10:54 pm ]
Post subject:  Re: Help: Bits of Sprint to identify
First picture, top left could be bonnet hinge plates?
Author:  Mad Mart [ Fri Mar 29, 2019 12:46 am ]
Yep, top left is bonnet hinge plates. The plastic part with yellow paint on 2nd below the plates is for mounting the side lights/indicators. Just below that, the screws with the washers on are gearbox tunnel mounting screws. The four big washers just below that look like washers from the subframe mounts.
Author:  GrahamFountain [ Fri Mar 29, 2019 7:23 am ]
Interesting, since the bonnet is mounted (if not that well) and the painter won't have touched the tunnel or subframe. Maybe its a treasure trove from a PO's restoration.
Author:  Carledo [ Fri Mar 29, 2019 9:04 am ]
Check underneath the front panel where the bonnet hinges fit, you may find nuts and washers where those plates should be!
Author:  GrahamFountain [ Fri Mar 29, 2019 9:37 am ]
Yep, no plates - though I couldn't say when they went missing between the previous work, the recent(ish) front end re-build, and the latest re-spray.
Author:  tony g [ Sun Mar 31, 2019 8:00 am ]
The plates are threaded normally to hold the bonnet. Quite important for keeping the panel firm. The 4 bolts without nuts in the stash are likely to be the bolts for them too. (1/4 unf)
Author:  GrahamFountain [ Sun Mar 31, 2019 4:08 pm ]
Thanks, I'll check if they fit.
I thought the rubber tube with the angled flanges would be something recognizable. Somthing 3/4 inch dia through a bulkhead at an angle of about 70 degrees?
Author:  xvivalve [ Sun Mar 31, 2019 4:36 pm ]
Is it a distorted steering column bulkhead bush?
Author:  Carledo [ Sun Mar 31, 2019 8:17 pm ]
Looks nothing like one and the shaped support plate for the bush means it goes through at 90 degrees. Nearest thing I could think of, is something to do with a radio arial. Otherwise, I dunno mate! One more bit recognised, the clear/rusty plasic tube bit is a damaged part of a front sidelight glass.
Author:  xvivalve [ Sun Mar 31, 2019 10:14 pm ]
That's why I said distorted!!!
Author:  GrahamFountain [ Mon Apr 01, 2019 7:18 pm ]
No, not off ones like those on the front of this Sprint. Could it be off a rear one?
Author:  Carledo [ Mon Apr 01, 2019 7:25 pm ]
Reverse light lenses (the only clear rear ones) are threaded. Might be off the later style front sidelight.
Page 1 of 1 All times are UTC
https://www.phpbb.com/
