You can eliminate components one at a time Stephen...
disconnect the steering coupling from the rack and
the steering rack track rod ends from the bottom ball joint arms.
This gives you four separate things to try,
1, turn the steering wheel
2 and 3, turn each hub assembly
and 4 move the steering rack from one side to another.
Hopefully this will narrow the search down.
_________________ TDC Forum moderator
