It is currently Sat Apr 20, 2024 2:05 am
 Post subject: Speedo drive 'O' ring
PostPosted: Thu Apr 25, 2019 12:36 am
Hi,
There is a more than acceptable oil leak from the speedo drive on my SPRINT.
I've bought a couple of the correct 'O' rings, But I'm a bit reluctant to get started on replacing it without some advice first.
Is the (new-ish) gearbox oil likely to run out in copious amounts? I figured I should raise the rear of the car and not the front, so as not to loose too much of it......or am I wasting my time.
Any advice on such a basic task?
Also, the reversing light switch seems to be leaking a bit. Is there any quick fix for that?
Thanks & Cheers,
Rob
"When everything seems to be going against you, remember that the airplane takes off against the wind, not with it". HENRY FORD
1915 Ford "T" Speedster (Evangeline), 1921 Ford "T" Tourer (Anastasia), 1955 Zephyr 6 (Purdey), 1975 Dolomite SPRINT (Daisy), & a couple of moderns.
PostPosted: Thu Apr 25, 2019 4:30 pm
Raising the rear of the car will reduce the amount of oil lost, but it's unlikely you'll get the tail high enough to completely eliminate it.
All I can suggest is, get the tail as high as you can, catch the spill in a nice clean container and put the collected oil straight back in! Unless it looks awful, in which case, change it all again!
Normally i'd say drop the oil out first, drain the box! But this is a Sprint and knowing what a PITA they are to fill, refilling could be the longest part of the job! So I won't!! :)
No quick fix on the reverse light switch either, i'm afraid. And with access to it as bad as they are, it's probably tunnel out to change it, though the leak is often from the fibre washer between switch and gearbox, the access is the same and you might as well fit a new switch regardless!
PostPosted: Thu Apr 25, 2019 9:12 pm
"Thank You" Steve,
Absorbed.
Cheers,
Rob
Users browsing this forum: Bing and 63 guests
