Talk to me about gearbox conversions… http://forum.triumphdolomite.co.uk/viewtopic.php?t=34977 |
Page 1 of 1 |
Author: | xvivalve [ Thu May 16, 2019 10:51 am ] |
Post subject: | Re: Talk to me about gearbox conversions… |
You describe the 4 speed TR7 'box fairly accurately; I suspect it would be short lived with 150 bhp behind it. I have the 5 speed '7 'box in the Quicksprint, it is OK for road use, but on a relatively tight circuit such as Castle Combe I found the ratios just wrong. Mad Mart was going round simultaneously and I could jealously hear him exploiting his overdrive whilst I was having to waste time with clutch and stick! It might be better on a more 'long legged' circuit such as Silverstone, but I haven't had opportunity to find out...yet... Other disadvantages of the LT77 5 speed 'box are it is heavier than a Sprint o/d 'box....even after you've hacked away at the bellhousing to get it to fit in a Dolomite engine bay! |
Author: | Bumpa [ Thu May 16, 2019 2:12 pm ] |
The Land Rover box, both LT77 and R380, are not only heavy but clunky old things. I have an R380 in my 3.9 litre MGB V8. It can handle the torque OK but is not a pleasant thing to use. Fortunately with a low revving V8 gear changing is not necessary too frequently. I once read a magazine report of the Morgan V8 when it first came out. The tester said that to win the traffic light grandprix, you just had to select a gear - any gear would do. My B is a bit like that! |
Author: | SprintV8 [ Thu May 16, 2019 6:05 pm ] |
The Mazda RX8 5 speed boxes are meant to be stronger than the 6 speed. 6 speed are electronic speedo. |
Author: | gmsclassics [ Fri May 17, 2019 6:49 am ] |
Post subject: | Experiences with gearbox while circuit racing |
I've inherited Toyota 'boxes converted to fit a Dolomite. The T50 (Sprinter) was not strong enough and soon wouldn't reliably go into third. The W5* series (Celica / Supra) tend to be heavy and ratios aren't necessarily what you need for racing so you need to know what ratios you want before you buy. I've also tried standard Sprint non overdrive, ST close ratio non overdrive and a standard Sprint overdrive gearbox. Depending on the circuit, the ST close ratio and standard overdrive produced the best lap times. However, the ST close ratio was difficult to get off the start line with such a high first and consistently lost grid places before reaching the first corner. As a result I ended up sticking with the standard overdrive 'box. I modified it to use overdrive on second, obviously you can't change from second into overdrive with full power, BUT changing into second overdrive while braking into a sharp corner (hairpin) produced a very useful additional ratio to keep on the power band when exiting a corner when second was too low but third just too high. Might only be for a few seconds but acceleration out of a tight corner can mean picking up a place. With seven potential ratios it also meant a narrow powerband could be used effectively. However 4OD was reserved only for the end of long straights. This was using a 4.1:1 diff ratio and most importantly an LSD. I would start with the diff ratio and LSD rather than gearbox as this, coupled with good tyres will improve race times the most. Also I used to 'crash' the gears ALL the time. You just can't wait for the synchro, but I found the 'box lasted a very long time (many years) even subject to that level of abuse. I actually only broke one over 17 years and 105 race meetings. I also found a large yellow warning lamp on the dash that showed when OD was engaged was extremely useful in the heat of a race to remind me what was going on! All this with a lightened flywheel, 7.25in clutch and centre release bearing from Rob at Sprintspeed Hope this helps Geoff |
Author: | soe8m [ Fri May 17, 2019 8:48 am ] |
You need another diff. Jeroen. |
Author: | shaunroche [ Tue May 28, 2019 5:43 pm ] |
Cheers for the latest replies Geoff/Jeroen, I have od on second and use it to good effect at very short sprint circuits like Curborough. The fastest circuit of the year is Goodwood where I only have enough power and speed to use od3 and direct 4 on the straight with Vmax around the 110mph area at the end of the straight and then direct 2 into the chicane. A different diff isn't the answer as it would take too much effort to set it up, shimming etc. where a gearbox change would be simpler in principle. I'm not sure it's that easy to get a 4.1:1 diff anyway! I think the plan at the moment is to build a std 4sp 'box and modify the subframe to facilitate a quick 'box change.... |
Author: | PaulB [ Tue May 28, 2019 6:03 pm ] |
How does a standard 4 speed help? Aren't they the same ratio as the OD gearbox? Has anyone managed to fit a Ford type 9 gearbox? If so there are loads of goodies available. There is also the possibility of the wide ratio gear set if you can find one. If I remember correctly it has a short 2nd and 3rd and standard 4th. The gap between the short third and 4th is filled by OD 3rd. I can probably find the gear ratios if its of any help. A short ratio diff would give you much better acceleration and the 4.1:1 CWP is easily available. Try TR enterprises. Paul. |
Author: | sprint95m [ Wed May 29, 2019 10:09 am ] |
Post subject: | Yes ... |
I did and had an article detailing the conversion published in Dolly Mixture during 2014(if I could find that edition I would give it's number). Ian. |
Author: | Carledo [ Thu May 30, 2019 11:52 am ] |
I've driven Ian's type 9 fitted car and TBH, I wasn't that impressed by it. Overall the ratios seemed too low, particularly 1st and the selection was very sloppy and imprecise, not something I normally associate with Ford gearboxes! This particular box is quite noisy in operation too. Having said that, I have no knowledge of the ancestry of the box (there are a plethora of ratio options, probably more than any other gearbox available) nor do I know exactly how the shift extension was modded to fit the Dolomite (which could affect shift precision) I do really like the Carlton/Omega 5 speed that I have in the Carledo, but it does have a couple of drawbacks, 1) there are virtually NO ratio choices and the 2nd/3rd gap is a bit large, this is very noticeable on short twisty circuits and places like Prescott hillclimb 2) like the Sprint box, the bellhousing is cast into the main case making adaptation to a different engine tricky. Though using a 'box originally from the BMW diesel powered Omega would at least put the starter recess on the correct side of the gearbox for a Sprint. Finally they are vanishingly rare in the UK, though there are plenty available,for sensible prices, via ebay in Europe. On the upside, its very strong and can easily cope with upwards of 250bhp, it's really short and correspondingly light, so it fits the hole easily and it has a really slick shift through an extension housing which is simple to modify for length. The Omega box also has the advantage of a concentric slave cylinder that matches seamlessly and easily to the Triumph master. Steve |
Author: | sprint95m [ Thu May 30, 2019 2:26 pm ] |
Post subject: | Okay… |
Quote: Having said that, I have no knowledge of the ancestry of the box (there are a plethora of ratio options, probably more than any other gearbox available) nor do I know exactly how the shift extension was modded to fit the Dolomite (which could affect shift precision)
It came from a Sierra 1800 turbo diesel Steve.This version of a type 9 has the lowest first gear option. Fifth gear isn't inside the gearbox casing, rather it is in the tailshaft housing so it gets noisier when fifth is selected but having said that, it is less noisey than the three rail gearbox was. It is filled with semi synthetic oil. The gear lever is homemade (because the Sierra one wasn't practical - too far forward). The selector rod is shortened, is all. When I got the gearbox I did notice that the gear lever didn't return to neutral, unlike the only other T9 equipped car I had driven (which was an 1800 petrol Sierra) but didn't think it mattered that much? You can get "short shift" adapters for a T9 but I haven't tried one. Ian. |
Author: | shaunroche [ Wed Jul 17, 2019 5:56 pm ] |
Hi Paul, I wasnt sure about the gear ratios being the same in the 4sp and od box, but I guess I'm better informed now! Depending on the venue, an od box would offer no advantages over a 4sp box and the latter would be much lighter. Thanks for the offer over finding the gears but I think they're very expensive aren't they? |
Author: | tom16v [ Thu Jul 18, 2019 2:42 pm ] |
I have a wide ratio box with an unrated overdrive ready to go in mine once I get round to finishing the engine to go with it. I’m hoping that this will give a nice spread of ratios between a standard 1st and fourth and OD fourth will stay as a cruise gear for long road trips. It cost me a lot of money in the end, but will hopefully be nice to use and in keeping with the car when it’s fitted. If I was to do it again I would consider a Tracsport type 9 box I think. |
