It is currently Tue Apr 23, 2024 6:12 pm
Post new topic  Reply to topic  [ 2 posts ]
 Post subject: Tie Bar
PostPosted: Mon Jun 17, 2019 8:18 pm
My tie bar end that go in to the axle are looking rusty and tired. Does the large washer part come out of the rod with the threaded part ?
Has anyone had theirs repaired and if so how ? I took an old poly bush centre bush out and it is exactly the same diameter and length as the end of the tie bar.. I thought the tie rod end could be turned down and the bush pressed on. However I then thought the turned part inside would be smaller diameter and potentially weaker.
 Post subject: Re: Tie Bar
PostPosted: Sat Jun 22, 2019 4:22 pm
you could have them spray welded and then machined to the correct diameter.
Paul
Users browsing this forum: Google, Trendiction and 37 guests
