Hi All
When I turn off the engine on my 1850 after a short or long run, I notice a mild petrol odour around the carb area, most noticeably at the air filter intake. I took off the air cleaner and noted the air filters were quite smelly - petrol smell - but no liquid to be seen. I have checked for leaks - none - on all fuel lines. The twin SUs' float chambers are not overflowing. I have balanced the carbs and using a friend's electronic analyser adjusted the mixture. Otherwise the car is running fine and pulling well, with no problems starting.
Do you know what would be causing the odour around the filters and what I can do about it?
thank you
David
