Hi, does anybody know the spec of Sprint prop bolts at the axle end ?
Any particular strength ?
Thanks, Richard
Prop bolts
- RichardHyde
Re: Prop bolts
You can download all my parts catalgoues and workshop manuals HERE There is also the "Standard Triumph hardware catalogue" which lists the specs of the various fixings so you can souce them elsewhere other than from the specialists. Just look up the part number for the specs.
Re: Prop bolts
I believe Chris Witor sells the correct bolts.
Yes ...
You are correct Mart,
not that I could dare to think any different!!
https://www.chriswitor.com/proddetail.php?prod=CW2009K
Chris sells the correct nyloc nuts in these kits
Ian
