It is currently Wed Apr 24, 2024 12:49 am
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Fri Jan 17, 2020 4:05 am
Just discovered this when completing an annual service. Only noticed as grease wouldn't pump into the rack, just all squirts straight out. At first though the nipple was blocked so went to change. It won't unscrew as whatever it is screwed into also rotates as well as moving side to side, within the limited space. All quite unlike spare racks I have where the grease nipple is firmly mounted and unscrews easily. I've already overhauled this rack in 2000 and again in 2010, with about 20k miles in between, but given this is summer in NZ and I'd rather be driving than doing repairs, I would rather leave this six months.
Everything else is quite tight, car drives beautifully, steering smooth lock to lock. Play in steering is 3-4mm max at the outer edge of the steering wheel. I would expect that to be dealt with by resetting shims to standard play in the rack damper and replacing the bush in the left end of the rack housing.
Can anyone see any issues with continuing to drive?
Geoff
PostPosted: Fri Jan 17, 2020 7:32 am
There must be a small bush rotating. Easy fix on the bench so personally I would leave it until you are ready. Sounds like you do a lot of maintenance and has been filled with grease before. Just watch out for any change in feel when driving over that period.
Users browsing this forum: DotBot [Bot], Google, Majestic-12 [Bot] and 45 guests
