Snapped wheel stud...doh!!!
storeyn
TDC Spares Officer
#1 Post by storeyn »
In a moment of being too over zealous I have managed to snap one of my wheel studs on my
New to me 1975 1500TC... it is fitted with sprint alloys
Should I get the 40mm length or 48mm ones....
And can they be changed in situ or do I need to take the hub off....
Thanks in advance
Triumph Dolomite Club Spares Officer
Track day Sprint for track fun....
Looking for something interesting for summer time daily use...
Skoda Superb 4x4 for everyday use...
Triumph1300
Re: Snapped wheel stud...doh!!!
#2 Post by Triumph1300 »
Front, or back?
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
Triumph1300
#3 Post by Triumph1300 »
Double post
BWJ
storeyn
TDC Spares Officer
#4 Post by storeyn »
Front ones...
Yes I posted in the wrong section then couldn’t remove it from the wanted section.
Hmm......
#5 Post by sprint95m »
storeyn wrote: Fri Mar 20, 2020 7:14 pm In a moment of being too over zealous I have managed to snap one of my wheel studs on my
Thanks in advance
There is only one length of wheel stud used on a 1500TC, in other words back and front are the same (part no. 158729)
these are 3/8" UNF.
I am pretty sure these can be changed in situ on the front.
storeyn
TDC Spares Officer
#6 Post by storeyn »
Thanks Ian
I was looking on rimmers website and they were quoting the two lengths I mentioned.
I wondered if the longer ones were for sprint alloys....
new to this
#7 Post by new to this »
The fronts can be changed on the car
#8 Post by soe8m »
storeyn wrote: In a moment of being too over zealous I have managed to snap one of my wheel studs on my
Thanks in advance
They all can be changed in situ but are you sure you want to replace one? They only break when there's metal fatigue mostly caused by wheelguns. Around 25 years ago just one day for a holiday to Italy one snapped when refitting the wheels again at the pre-holiday check. To be sure I set the torque wrench a few NM higher to check and 5 more did snap. These studs aren't that great but normally you really have to do your best to break one and if you did manage without using an elephant I would replace all.
cliftyhanger
#9 Post by cliftyhanger »
Was this with the proper 3/8 sprint wheel nuts? Surprised the thread din't strip on the alloy nut way before snapping the stud!
#10 Post by xvivalve »
It was common on early Sprints for the studs to neck at the point of exit from the hub and eventually sheer, it's why they increased the size to 7/16". Not sure if they ever found out why it happened, but it was peculiar to the use of alloy wheels.
I have loads of good used 3/8" studs if you want some?
#11 Post by MIG Wielder »
In the case of Sprint studs the workshop manual gives the 3/8 in stud tightening torque as just 50 lb.ft.
The 7/16 in stud torque is 70 lb.ft
This is a lot less than a modern.
Sprint manual 06-2 refers.
David Kirk
#12 Post by David Kirk »
I just changed a snapped stud on my Spitfire (rear). but very similar to a Dolomite. I used a ball joint separator and some appropriate sized sockets to push out the old stud and then push in the new one. On the rears you will have to remove the brake shoes I suspect.
You can punch out the old but risk damaging something with too much force. You can pull the new stud in with a wheel nut and washers to allow the stud shoulder to come through the hub but if it is tight, you risk snapping the new stud I would suspect.
Years ago I had some new tyres fitted at a tyre shop. They started tightening the wheel nuts to 120nm as that's what they always did. I had to shout across the shop to get them to stop before they broke something. According to Haynes, 60nm is good for Steel wheels and 67nm for alloy wheels with 3/8 studs, 94nm for alloys with 7/16 studs.
I always take loose wheels to the tyre shop now.
At the risk of hijacking, can 7/16 studs be fitted to a hub with 3/8 studs without modification or is it possible to drill the hub to take the larger studs?
David
Dolomite 1850HL Auto
Dolomite 1500HL Manual
#13 Post by Carledo »
David Kirk wrote: Wed Mar 25, 2020 12:25 pm
David
You can fit the 7/16" studs to a 3/8" hub no bother at all. The trick lies in getting hold of the 7/16" studs which have been NLA for many years and are about as easy to buy as hen's teeth!
There are several choices to uprate the studs though, you can get MkI Escort 7/16" studs from ebay and they'll fit with minor modding or you can go for series I Freelander or MGF 12mm studs which will fit the hubs and uprate the nuts accordingly. Other solutions are probably out there, but those are the ones I know of!
new to this
#14 Post by new to this »
Carledo wrote: Wed Mar 25, 2020 1:20 pm
David
Stag wheel studs are 7/16 there available and they fit dolomite hubs the rear ones are a bit longer couple mm
#15 Post by xvivalve »
Incidentally, you need to separate the disc from the hub to extract the studs.
A sharp tap with a hammer releases them.
