I beg to disagree entirely.
I test 40 - 50 cars a week. If something deserves an advisory it gets one. The "free text" as you put it is entirely discretionary and you can put what you like. The only communication ive had through the "special notices" procedure is a reminder that the MOT is an official document and any silly or offensive remarks may result in disciplinary action. "Various oil leaks" is fine. Its not going to be possible to determine where they are coming from in a 40 minute MOT. You are merely advising that you have seen them. What happens if, for example, a week down the line the power steering fails due to a fluid leak that was not noted on the MOT and was masked by general oil leaks from the engine? You will have no defence as a tester if you have not advised that its generally oily and harder to examine fully. Sadly, its all arse covering because thats what you have to do.
My last response on this as it's diverting the thread away from the original track.
Please have a read through the DVSA Matters of Testing for the DVSA current positions on such things.
On advisories, these will be of note:
https://mattersoftesting.blog.gov.uk/wh ... dvisories/
And
https://mattersoftesting.blog.gov.uk/gi ... ht-advice/
To quote directly:
Extra service
Another thing we noticed is that you like to provide your customers with a great service. If you spot a problem that isn’t part of the MOT, lots of you still want to tell them about it. This is because you take pride in your work and want to do a proper job. That’s great and we absolutely encourage you do that.
We just don’t need to see it on the MOT. It’s a structured test and only things that belong in the MOT should be included.
If you want to tell your customers about additional issues you find out while conducting an MOT, please do so. You can just do it in the same way you tell them about issues you find while servicing their vehicle. Consider it part of your customer service, not part of the MOT.
Also:
As pointed out in the MOT Inspection Manual, it’s considered best practice to advise the presenter about:
- any items which are near to, but which have not yet reached the point of test failure
- any peculiarities of the vehicle identified during the inspection
- any defects on non-testable items which are found during the inspection procedure
But yes I'm just a random internet bloke on a forum. So yes feel free to disregard everything if you so wish, makes no difference to me.
Just make sure you have a read up of the above, directly from the horses mouth on those (and other) DVSA posts and make your own mind up...
