Really pleased to have received my pin stripes supplied by the club, quality looks great!
Before I try and fit, any advice?
How far back should the taper start on the front wing? Where the cuts are made between doors/wings, is the small remainder folded over the edge of the doors or is it cut level with the end of the panel to prevent peeling.
Totally agree about the quality of the club strip, they're excellent.
Remember the stripes go under the chrome on the rear wings, see a few that stop short. Apparently there could be difference in sides (from the factory) as there was a fitter on each side applying them, and accuracy wasn't their highest priory. Here's photos of my front wing, I hope that helps.
Thanks Murdo, the photos and dimension help a lot.
I did have a look at your restoration posts whilst looking for some pictures to try and answer my questions - what a superb car you have, looks great!
Unfortunately my car has some ill fitting panels, so the swage line isn’t great. Hoping the stripe will take the eye off of it a little.
Am I right in saying the front wing stripes are fitted separately as they come as one piece, the doors and rear wing are done in one hit, cutting between panels after.
Should you pick up on this update, how did you get on with the Chris Witor polyurethane engine mounts?? Need some for my car, I did fit pattern ones but when I looked under the car the oil pump was just about touching the steering rack, so had to put on usable second hand ones!
Thanks again for your help,
Chris.
