Hi
I have replaced the Main and Big End bearings with the +0.02 ones, and it sounds a whole lot better.
No rumbling present at all. Thanks again for all your help diagnosing that.
The end float was fine, I was using the old thrust washers so thought this might be the case.
However I was running the engine and intermittently I get a strange noise from the clutch area.
the noise comes and goes, I tried pulling the release bearing away and I can visibly see it is not turning at all in the away position, but the noise I still there, so it is not that,
The noise is present with or without the clutch pressed, but can disappear all of a sudden.
Any ideas what it could be? and more to the point should I be concerned?
Thanks, Darrell
https://youtu.be/LUOZkXc9kNk with the noise
https://youtu.be/HaqxTTEaAww Without the noise
