This sounds like an issue i had with my new starter motor when the garage fitted it for me.
It was fine for a while but then the routine for starting the car became turn it over (no spark not even trying to start) release the key and it would start just as you release the key.
The problem was the new starter motor didn't have the wire to supply full battery voltge to the coils whilst cranking like the original starter. (the garage who fitted it should have probably noticed)
I presume as the battery got older the voltge was too low when the starter motor was turning over, but as soon as you relese the key the engine is still turning and the coil gets more voltage and the car starts. (like a mini bump start)
I fitted a relay to cut the power to the electric fan and supply battery voltge to the coil on cranking. Been fine ever since.
If you have the original starter is the wire from it supplying the battery voltage to the coil on cranking?
(Forgot to say i have an 1850 with a lumenition as well)
You have a ballast system.
A ballast system works by using a 9v or 6V coil which is fed 12v via a ballast resistor. That supply is what you use when you're normally running and not cranking over. When you're cranking you bypass that and the coil gets the full battery voltage. Which is suppose to compensate for voltage drop during cranking.
With no feed from the starter, your coil would only be getting supply via the resistor, which would explain your lack of spark. Unless you had a strong battery.
