On the Dolomega, I'm going to cover the holes in the heater plenum with "grille mesh" that lets air in but stops leaves etc getting in.
Just have to work out a way of getting the mesh panels to stay in place but still be easy to remove in case of need. I always remember that the poor b**ger that has to work on it next will probably be ME!
Steve, I'm ahead of you there - see photo. I used stainless mesh in three pieces. They are cut to just fit between the rubbers and have the ends folded so that they locate on the body. When the bonnet is shut the only visible gaps are where the washer jets sit. They stay in place but can be easily lifted off if I need to.
