It is currently Tue Apr 23, 2024 9:42 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Sat Oct 17, 2020 6:09 pm
Does anyone know if the Triumph Stag drag strut can replace the Dolomite one? The nuts and bolts that hold it on are a similar size, the hub end bolt is same diameter but 1/4 inch longer.
I broke my Dolomite one taking the front suspension apart and Rimmer Brothers don’t stock a replacement.
PostPosted: Sat Oct 17, 2020 6:30 pm
If they were the same, they'd share a part number.
I can probably find you a good used item; are you on about 218482 corner of subframe to lower wishbone?
 Post subject: Well
PostPosted: Sat Oct 17, 2020 6:52 pm
Not Stag but T2000.
Triumph did do this for ST (Special Tuning),
Since it is such a good design,
I think it is a pity they didn’t make use of this on the production cars,
They have to be shortened and reinforced at the TCA end.
Superflex sell replica ST bushes.
Chris Witor sells remade cup washers, reinforcement sections and HD stainless steel washers.
I got NOS T2000 tie bars from Rimmer Brothers ( in a sale).
Ian
PostPosted: Sat Oct 17, 2020 8:48 pm
I dont think they are the same,but can check for shore tomorrow
PostPosted: Sat Oct 17, 2020 9:19 pm
I think the anti roll bars fitting is different to the drag strut.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
480Hrs @ 14/03/2024
Working on a ratio of just 7Hrs a day not including driving to the Sprint.
That equals to 68 days that doesn’t include weekends.
Member TDC no 0471
Project 13B Sprint now back on.
 Post subject: Re: Well
PostPosted: Sun Oct 18, 2020 2:33 pm
Not Stag but T2000.
Ian
So is the drag link is too long and flimsy? Does Chris have a website or anything?
Thank you
That would be grand, thank you
From the rimmers site, they don’t share the same part number as how the anti roll bar attaches is different. On Dolomite, it’s hole through and a crush tube, on the stag/t2000 it’s a tab, I just meant is the overall dimensions similar?
I was going to replace my anti roll bar with something that allowed for that anyway as I’m not a fan of the way the Dolomite one mounts to the drag strut, think I read something about if you polybush the roll bar it can get ripped from the subframe, I also want a touch of adjustment so might go to something like an mx5 bar as there’s plenty of aftermarket for them
PostPosted: Sun Oct 18, 2020 3:12 pm
Sprint Speed do them but adjustable
Exchange thou.
http://www.sprintspeed.co.uk/pages/prod ... uspension/
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
480Hrs @ 14/03/2024
Member TDC no 0471
PostPosted: Sun Oct 18, 2020 3:26 pm
The Stag Drag strut is bigger. Bolt hole centre to bush face is 300mm. On the Dolly it is roughly 270mm. I think the wheel end is also slightly wider. See attached pics of a Stag drag strut - also the a/r bar mounting is different, but you already knew that:)
Hope that helps.
Roger
1971 Stag Auto White
PostPosted: Sun Oct 18, 2020 3:43 pm
I've got T2000 on my car, see topic
https://forum.triumphdolomite.co.uk/vie ... =3&t=25050
 Post subject: Yes.....
PostPosted: Sun Oct 18, 2020 4:01 pm
Thanks Tony, you have saved me the effort of searching the forum for your thread!
Since you did your installation, Chris Witor has had the cup washers remade.
They locate the bushes very well indeed.
https://www.chriswitor.com/proddetail.php?prod=CW1388
Ian
PostPosted: Sun Oct 18, 2020 4:13 pm
:thumbsup:
PostPosted: Sun Oct 18, 2020 4:17 pm
Not Stag but T2000.
Ian
It is too long but it is not flimsy. The reinforcement plates are needed to reduce it's opening by 8mm to fit snugly on to the Dolomite TCA.
https://www.chriswitor.com/index.php
https://www.superflex.co.uk
Ian
PostPosted: Sun Oct 18, 2020 6:12 pm
Not Stag but T2000.
Ian
Thank you
You said you broke yours,where did it brake can it be repaired,i strengthened my by welding tabs on the sides
PostPosted: Fri Oct 23, 2020 10:08 pm
The threaded end snapped off from the nut rusting to it, so not very salvageable, unless I turn it into an adjustable one somehow.
From what everyone has said above, I might just go ahead and use the T2000 with the “ST” bushes, that Chris Witor does a “fast road” rubber for the T2000 so I’m going to use that with 2x4mm spacer washers to make it fit and use the T2000 ARB mount to attach a Mx5 anti roll bar so it can be adjusted or replaced easier
PostPosted: Sat Oct 24, 2020 9:26 pm
Sprint speed sell adjustable ones,but i cant see why you couldnt repair yours if its just the threaded part thats broke
Users browsing this forum: DotBot [Bot] and 33 guests
