There were a lot of Sprints exported to California which all had the HS8 and fast road camshaft fitted as these were part the emission kit compulsory in some export countries. The 5000 sprints shipped to Johannesburg all had an oilcooler kit and larger radiator fitted and a sump guard for the rough territory to homolgate these......
I don't see where there's a possibility to misread this. You clearly claim that "There were a lot of Sprints exported to California which all had the HS8".
My understanding is that the Sprint engine had no chance of meeting US federal emissions requirements, which changed significantly in 1976, without the EFI and smog pump being developed for SD2 (other slant-4 engine cost reduction programme developments may have mattered as well) - there is a (P reg.) engineering development SD2 in the BMM collection at Gaydon with that Bosch EFI and some of the mods to the head for the smog pump. But SD2 was cancelled before the end of 1975 (maybe early 1976 if you include the paper study that was TM1) following BLMC going bankrupt in 1974. So I just don't get where there were "a lot of Sprints exported to California".
My other point is that if "There were a lot of Sprints exported to California which all had the HS8", and or cars fitted with Webers, they would be well known. Yet they are not. But if they are real, then there must be evidence of them. If they are virtual, paper ones, then they don't count to homologating modifications that affect performance of a Group-1 car.
I simply don't accept "Just give it a name, make it a standard production part on paper, fit it to cars on paper and you can homologate it as a standard production part to be able to use it on a legal gp1 car." as being true. There is no way that fits with what is said in any Appendix J for Group-1, which gives the rules written by the CSI and published by the FIA, for what may and may not be given homologation approval by the CSI. It's nearly true for Group-2 before 1976, when the 100-off rule allowed this approach for a range of component types on the production of 100 kits to modify 100 cars. But that rule just did not apply to Group-1 in any way, shape, or form. It's very clear Group-1 was supposed to be for showroom cars modified only for safety, not performance.
You might try to argue that Appendix J didn't apply to the Group-1 Sprints for some reason. And I might accept that in the special case of the BSCC Group one and a half cars because there's evidence for that. But I'd want to see additional evidence before I'd believe it for any other purpose.
As to historic racing/rally series accepting anything that was ever approved for Group-1: from what I've read about Marcos cars being raced, they aren't, or at least haven't always been, even that strict.
So, given that the use of the term "Group one and a half" in the sporting press clearly implied they thought there was something about them that bent the Group-1 rules enough for comment, and these approvals clearly require the Group-1 rules about producing another 5000 for a modification affecting performance to have been bent, I suggest they are related.
