OK better late than never..
I took the decision to replace the rear brake cylinders and brake shoes and when replacing them there was no fluid in either cylinder or leaking from the pipes themselves.. Not Good.
So set about changing the flexi hose, rear axle to body. Not so easy with the car on axle stands but as soon as I undid the front flexi connector (forward one bracketed on the body) I had fluid leaking out of the copper pipe from the PDWA valve.
Once the new armoured stainless hose was on at that end, I was playing in fluid running out the flexi pipe trying to connect to the copper at the axle end.
Once all the rear brakes were connected back up (wasn't straightforward due to reasons I won't bore you with) I had fluid running out of the nearside rear bleed nipple so decided to check the flexi I had removed. I couldn't push a wire through and tried adding vacuum bleeder at either end and as you can see in the picture, the hose is well and truly 100% blocked somewhere internally.
So if you don't have fluid at the rear bleed nipple try undoing the inlet pipe at the offside cylinder and work back from there to the flexi until you do find fluid, as has already been suggested, gravity alone should allow fluid to run from the master cylinder back to the rear of the car without needing to press the brake pedal.
The worrying thing is that I have driven the car since June with no rear brakes.......
If all else fails, I'm still supplying the PDWA bypass kit if you need one!
Didn't need to do anything with the PDWA as you can read the problem was elsewhere in the system, but thanks for the offer.
