It is currently Thu Apr 18, 2024 8:00 am
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Feb 26, 2021 1:41 pm
Oh, it might be worth noting that the electronic clock, like the eclectically wound clockwork one, keeps running for a while after power is removed. I think that's because there's energy stored in the spring in the electro-mechanical escapement. But its only for a few seconds rather than 10s or hundreds of seconds with the eclectically wound clockwork ones. And there's no clunk as the solenoid rewinds the clockwork.
Whereas, the quartz clocks stop within two seconds of power being removed.
PostPosted: Sat Feb 27, 2021 8:56 pm
I finished the mk2 version of Frankenstein's clock insert. This one uses the green plastic bit, dial, and reflector of the electronic clock, which look to be the same as those in the quartz clocks - from what I can see without taking one apart. That seems to me to give a much neater solution. Though its a bit more work shortening the green plastic bit.
The illumination is dispersed by two 3mm thick perspex mirrors held 10mm apart by a perspex disc, and a pair of 10mm long tubes tight around that and tight in the body of the clock. The bulb sits in an 8mm hole drilled through the back mirror and 10mm disc. The tubes are only 1.5mm wall thickness, and it might be better if they were about 3mm. But considering the issues in getting them to fit in the body, if I decide I want it brighter, I'll look for a brighter bulb. The one in there is about 0.2W, and I can get at least a 1W led in a GLB281 form, though I may have to drill the hole out a bit. Another solution would be to move the bulb holder to the middle, but it would have been a heavier soldering job than I can manage in the house. Filing perspex I can just abut get away with, if I sweep up after.
PostPosted: Sat Mar 27, 2021 3:56 pm
It turns out that there's a possible problem with these intermediate clocks, i.e. ones that sweep the second hand smoothly (about 4Hz steps) not step every second like the quartz ones, but don't go clunk every minute or two like the electrically rewound ones. These clocks have an escapement inside that uses a couple of static coils and a couple of magnets on an amature, the coils used as a sensor and a magnetic driver for a two transistor pulse generator, working against a hair spring as an escapement.
The problem is that the glue used to hold the magnets on the amature doesn't last. While they still stick to the amature magnetically, given a good knock the magnets can move in and out relative to the centre. That changes the time constant of the amature and spring, like changing the length of the pendulum in a grandfather clock, and they run faster or slower, possibly by more than the adjustment on the hair spring can compensate for.
Hopefully, the picture above shows the top magnet can move. On the left, it's about where it should be. On the right I've moved it in as far as it will go at one end. This would make it run seriously fast, and moving it in by even less than a millimeter seems to be enough to make it run so fast the adjuster can't correct.
I've got two here where one of the magnets had come unglued and could slide on the amature and change the time constant. So this is not an isolated failure. The one pictured above is the one where the bearing has gone and the clock can't be fixed. The other works, but was gaining tens of seconds a day at the slowest it could be set.
So I've re-glued the magnet to the armature on the working one. The worry is that the glue, in effect, moves the mass out a bit, and slows the clock too much. So I used the smallest drop of superglue gel I could get in there. And I must have got it about right, because it now runs slow at one end of the adjustment and fast at the other.
Fixing this problem with the magnet does mean taking the bezel off. And that's a problem in its own right because the bezels are generally a bit brittle and will tend to split. So much so that the splits are visible when it's all back together and in place. But with care, and the right tooling, it is possible to get the bezel off and back on, and fix one of these that won't adjust to run right, or needs re-setting if you hit a big enough bump, etc.
PostPosted: Thu Apr 01, 2021 2:26 pm
My clock always seems to keep great time
Bizarrely last week before the clocks moved, I had to remove the battery as my sons car needed a jump start, as all of the other cars were not in a position to be moved to the correct spot.
The dolly battery is an easy remove since I have wing nutted the clamp.
Anyway got him jumped off and slung the battery in the garage ready for reinstatement later.
Installed it Sunday then went to take the car for a run on Tuesday this week looked at the clock and it was 5 mins slow. Go figure......... :shock:
Trevor
2017 Jaguar XE R-sport
PostPosted: Thu Apr 01, 2021 6:54 pm
I assume you set it right on Sunday and it lost 5 mins to Tuesday, not that you put the battery back n times 12 hrs + 5 mins after you took it out.
If its the intermediate type with the magnets mentioned above, the hairspring tension control is under the paper sticker on the back. Clockwize looking at the back to speed-up a slow clock. On the electrically wound clockwork ones, the hole's not covered, and its clockwise to slow a gaining clock. The quartz one I buggered didn't have an adjustment.
I'm still looking for another working quartz one.
PostPosted: Sun Apr 11, 2021 1:23 pm
I think this is the last incarnation of the modern quartz insert in a Kienzle body.
The 12V AAA battery replacement is two diodes in series across the battery terminals with a 1k Ohm resistor up to the 12V supply. 2k Ohm is too big and 1k is so close to the limit that the clock stops when I put a multi meter across the battery input terminals.
I'm just finishing repairing a Kienzle out of a P6. The case is different in the way it mounts, but the internals are compatible - though the backlight is blue not green and the hands, while a slightly different shape, are a much better pressed metal design than the ones in the Triumph versions, even the Quartz ones. Presumably the Rover hands were tuppence a hundred more expensive.
PostPosted: Sun Apr 18, 2021 8:55 am
Informative post Graham! Cheers...
PostPosted: Sun Apr 18, 2021 12:35 pm
You're welcome
PostPosted: Wed Jun 02, 2021 11:39 pm
Update:
Thanks to all on this useful thread about quartz models..My early face (right hand side of photo) has just been swapped onto a later Quartz (from a '78 Dolomite)
Fits and working great! Finally accurate more than twice a day :lol:
PostPosted: Thu Jun 03, 2021 10:45 am
Update:
I did set out once to swap the internal faces over from one of them not so good transistorized magneto-mechanical movements to a quartz one, so they'd look the same except for the second hand stepping.
It would have worked too, but I broke the quartz one taking it apart - there's some unsoldering to do at the back as well as the nuts. Even more annoying because I didn't need to take it apart that far, just take the bezel and hands off the front, and the face (and if I remember correctly, the plastic backlight sleeve) just lifts out. So I went for the cheap one from China as an insert and put my own face on it - narcissistic I know.
PostPosted: Thu Jun 03, 2021 1:28 pm
I applaud you for attempting that (and your custom faceplate!). I didn't want to sacrifice another gauge so had a local gauge specialist swap my early face onto the Quartz, really happy with it..
I did try everything with the original movement, even after service they work for a while then go haywire, at least mine did..last week it ran 40 minutes overtime, then slowed by another 20 before the light retired and arms moved again :lol: A tad 'poltergeist' but entertaining!
PostPosted: Thu Jun 03, 2021 4:07 pm
Was it expensive having the face transplant?
WRT to the magneto-mechanical doings, the chances are it's that moving magnet issue I mentioned. Because the magnets still stick to the armature, some one cleaning the clock might not see one or both magnets were, not so much loose as able to slide a bit. So it will move a little every time you hit a big enough bump, and the frequency of the escapement will change up and down, depending on which way it moves. It will re-glue well enough. Still mightn't last another 40 years though.
PostPosted: Sun Jun 13, 2021 6:45 am
Graham, thanks for info explanation on the magnet, very informative..
Transplate around $100AUD but he also cleaned / oiled the movement hopefully good for another few years..with original purchase / shipping from the UK probably double that all up haha..worth it for me though as I love do love centre clock, part of the look in our cars..plus the wood restored now I guess that's one more gauge I hopefully don't have to remove too often..
Now if I could just fix that jumpy speedometer :lol:
PostPosted: Tue Jun 07, 2022 12:28 pm
I just noticed this on eBay:
https://www.ebay.com.au/itm/144578014842
It seems it is in Australia. There is no indication of size and it does not have the black on the rim.
Also these:
1975 Dolomite 1850 manual (no overdrive), French Blue
Owned since 1976.
PostPosted: Mon Jun 13, 2022 7:02 pm
I have three 60 mm diameter, Dolomite 1850 & Dolomite 1500 HL clocks.
The electrically wound, clockwork ones have a grey plastic ring that slides over three spring clips on the case to locate.
One 60 mm clock, with a grey plastic ring (becomes brittle with age) that slides over three spring clips on the case to locate it, originates from an early-model Triumph Dolomite 1850, of the vintage which had a large, non-illuminating rocker switch for the hazard-warning lights, two direction-indicator tell-tale lights in the 8-segment warning-light cluster, and a heated rear-window switch with integral tell-tale light. The clock’s black face is marked “KIENZLE” and “W•GERMANY”. This clock, whose style I prefer, which closely matches the original factory-fitted instrumentation associated with my N-registration, 1974 Triumph Toledo 1300 “HL Special”, was retro-fitted to my car in 1984, along with the Dolomite 1850 dashboard which came with it.
I haven't got one of the Kienzle quartz ones yet, but from what I've read and been told, the quartz ones have a U shaped bracket with a single central nut, very like the way the 2" meters in the main dash mount.
The other two 60 mm clocks, with single screw-stud & nut retained U-clamp to locate them, originate from late-model Triumph Dolomite 1500 HL cars, of the type which had dual-circuit brakes. The black faces of both clocks are marked “QUARTZ” and the face of one clock is also marked “W•GERMANY”. Both clocks have a white hour-hand, white minute-hand and a yellow second-hand. Neither of these clocks, have any markings identifying the manufacturer. If anyone is interested, I would be willing to part with at least one of these.
Regards.
Nigel A. Skeet
Users browsing this forum: Bing and 39 guests
