The area difference from 48mm to 54mm pistons is 1:1.266. The moment difference (from piston centres) is 1:1.142. Together they give a total increase of 1:1.445, or about 45% increase.
I still think that's a lot.
For the Puma disc & caliper, that's the same area ratio, but the moment difference goes up to 1:1.241 and the total is 1:1.570, or 57% more effort.
If I think that 44% is a lot, I wonder if you can guess what I think of 57%.
What does that do to the pedal length is, I suppose the next question.
Also, if you could increase the grip from the tires enough to take advantage of either of those increases in front brake forces and actually get 40 or 50% greater maximum deceleration, what does that do to the ideal brake balance (where front and rear wheels all lock together), how much less rear brake force would you need to get to the same safety margin from it, and does the LSV do anything to save you - when it works?
Well I'M personally happy with the figures now. Especially as the original calculation of 54% for the TJs (based on erroneous data - not your fault) is pretty close to the 57% of my uprated TJs! My upgrade is definitely not for everyone, it was never meant to be. The original intention was to provide an easier drive for SWMBO who can't match my pedal pressures, driving a powerful and torquey fully auto trans car which, by definition, has no engine braking to help the driver scrub off speed. The spin off is a possible advantage with extremely modified high power/high grip cars. Even I would say it's probably too much for a stock-ish street car. Though at least, it's effectively free, the bigger discs and Puma calipers are the same price as the smaller ones.
The pedal length is the same for my upgrade as for the stock TJ setup as the pistons are the same (54mm) diameter, the dual purpose cure of using the smaller (0.625") 1850 rear cylinders works just as well on both designs.
I agree there's little likelihood of you actually being able to exploit a 40-50% increase in braking power, you'll not generate enough extra grip, even with the benefit of soft and sticky, bigger footprint 195/50 Toyos such as I have. However, I don't really look at it that way, as I reckon you are using at least half of that increase to get the brakes from "barely adequate" to "acceptable". The rest is a bonus! If they were good enough in the first place, there'd be no need to upgrade!
So far, i'm happy with the brake balance i've got. I may have erred a little too much on the forward side on the Carledo, which has the Vauxhall pressure limiter on the rear brakes as well as smaller cylinders against standard size TJ front brakes. The limiter is a hangover from before I fitted the TJs and had to find something to do duty for my non existent LSV and which i've never got around to removing. While the rear brakes are still powerful enough to give good readings at MOT time, it's not possible to lock the rear wheels at all on the road, even when I persuade the fronts to lock solid, something I personally find reassuring! So OK, if you want to be pedantic, my brake balance is NOT "ideal", but it suits ME!
However, the Carledo is, in many ways, a special case. In my pursuit of lightness, I have used a short tail 2 door shell and most of the dietary benefit has been at the rear, no back doors, no back seat, spare wheel, bumper, tools etc and only an 8 gallon fuel tank. To redress this imbalance I have a GRP front end, i've relocated the (bigger) battery to the boot, the engine and gearbox is 4" further back and I top up the tank when it gets down to 1/2 full. Still the back end of the car is extremely light compared to a stock 4 door causing me the weird problem of not being able (for quite some time, fixed now) to get the rear suspension SOFT enough! This will also have an effect on brake balance so i'm gonna leave the PLV in place for now!
I've not fitted a PLV on the much heavier Dolomega. time and testing i've not done yet will tell if I need one. If it turns out I DO need one, I have one in stock, so no worries. Whilst the LSV is a better technical solution (being "self adjusting" for conditions) my distrust of the standard design and high seizure rate (100% IME) means i'm happy to use a "second best" solution that IS reliable.
A couple of other points, there ARE 48mm calipers available for Fiesta, KA and other small Fords, but AFAIK, these are ALL for solid disc cars and miss fitting the vents (with new pads) by about 1/4", so near and yet so far! (Ask me how I know!) I suspect YOU would be much happier with TJs that had only 48mm pistons, decreasing their advantage considerably, but still curing the fade problem! I suppose it would be possible to fit these, if one was to deliberately shave 1/8" or so off each of the new pads.
The other point concerns LSVs in general, there are loads of types and designs for LSVs, many of them fitted to estates and light commercials (think Astra van) in the 80s and 90s (maybe still) So you'd think that, being unhappy with the Triumph one, I could just adapt someone elses to fit. Except for one small point, they ALL suffer from the same malady, i've lost count of how many i've had to free off or replace on non Triumphs for MOT over the years, it's a REALLY common fail. The ONLY thing that surprises me is how most testers (including my own tame one) seem to ignore or not notice the Sprint one is seized!
