It is currently Thu Mar 04, 2021 10:23 pm
 Post subject: Paint colour underneath
PostPosted: Thu Feb 18, 2021 8:58 pm
Just on with tilting over the Sprint next week for ease of access to get at things, plus weld/repair paint job underside.
Question - was the colour underside the actual body colour ? - ie Magenta in my case or a black underseal (use the term loosely with BL)
Thanks in advance
VW Mk1 Golf GTi Campaign - Alpine White (A reg)
Dolomite Sprint - Magenta (M reg)
Vauxhall Omega MV6 - Champagne (S reg)
BMW 325i Touring - Lachs Silver (F Reg)
PostPosted: Thu Feb 18, 2021 9:17 pm
Online
The inside of the wheelarches may have been lightly painted under the dubious underseal and the rest of the underside may have a hint of colour in the way of overspray, but the general factory finish underneath was a brownish red primer.
The whole car wasn't even undersealed from new, just a few of the more vulnerable bits. They left a proper job to the aftermarket, Ziebart was well thought of, it certainly preserved both of mine long enough for me to get them.
HTH, Steve
'72 Triumph 1500FWD in Slate Grey
PostPosted: Thu Feb 18, 2021 9:23 pm
The closest match I could find to the unpainted but in my case an undersealed bottom to my Sprint was a red PA10 Vinyl etch primer. As a vinyl coating it has lasted extremely well on my 45 year old car.
Check the topic HU 5089 Dolomite Sprint Restoration and scroll down to the posting dated 16 Sep 2020.
You can see a photograph of the newly painted chassis rail and match that against the area around the handbrake mechanism which has been wiped down to remove the oil coming from the rear gearbox seal. It looks to be the same.
Robert
PostPosted: Thu Feb 18, 2021 10:10 pm
TDC Cheshire Area Organiser
If you are going to use the car after spraying the colour you decide on, consider using this https://www.bilthamber.com/corrosion-pr ... s/dynax-ub on all the usual rust areas It really does work. They also do Dynax S50 for the cavities.
PostPosted: Thu Feb 18, 2021 10:19 pm
Thanks guys
I’ll probably get it properly under dealer that can then take a paint on top
I’ll decide nearer the time
Users browsing this forum: AhrefsBot [Bot] and 1 guest
